I have two EN-EL4 batteries which have developed a fault when charging. I plug battery into charger and initially just the 50% light flashes After several minutes all the charge leds and the CAL ON flash. This scenario is not covered in the instructions. To be safe I unplug the battery.
Has anybody encountered this problem and have a solution. I suspect it is a battery fault as other batteries I have charge correctly
