Looking for a Dp3 viewfinder...
Posted 28 February 2018 - 08:28 AM
Had a look on ebay but slim pickings and what is there seem to be going for more than the camera is worth!
Any ideas of where to start looking?
Or does anybody have one they're looking to part with?!?
Thanks all
Posted 01 March 2018 - 04:02 AM
I'll just say good luck on your quest. The F2SB is the rarest version of all professional Nikons with a production run of only 8 months or so and the Photomic Dp3 seldom turns up, if at all.
Posted 01 March 2018 - 08:40 AM
I find the DP2 not particularly user friendly
Would any of the later post dp3 models be easier to come by? Presumably they meter in a similar way?
Thanks for saving me a lot of time looking for one!
Posted 01 March 2018 - 09:46 AM
They were made in much larger numbers and use the Ai ridge instead of the rabbit-ears. I think the DP-11 is match-needle and the DP-12 uses diodes but I am not sure. I sold off my F2 bodies some years ago.
Posted 01 March 2018 - 01:09 PM
Posted 01 March 2018 - 01:25 PM
You are absolutely correct in that. The F3 finders aren't photomics as a starter and the metering electronics are down in the body.
What is it you dislike about the DP-2?
Posted 01 March 2018 - 10:18 PM
1 The red diodes aren't always the easiest to see- could be mine is on the go perhaps
2 You only get over, under or correct, with no idea how over or under you may be
3 The fact they both light up when you're metered correctly is a slight design flaw to me as you have to check for both the whole time. A minor point that one.
(I think that is the DP2 from what I've read online. I inherited the camera so can't be sure!)
Posted 01 March 2018 - 11:20 PM
To summarize the five Photomics for the F2:
DP-1 uses a needle,.
DP-2 uses two diodes.
DP-3 uses three diodes.
DP-11 uses a needle and is Ai.
DP-12 uses three diodes and is Ai.
The DP-3 and DP-12 meters down to EV-2, the others down to EV1.
Both the DP-11 and DP-12 can be used with pre-Ai lenses, but only with stop-down metering.
- TBonz likes this
Posted 02 March 2018 - 12:55 AM
Don't forget about the meter less DE-1 viewfinder and handheld meter option. That is what I prefer, makes for a much more compact camera body.
Posted 02 March 2018 - 01:58 AM
I've got a reasonable one on my phone but obviously that only really is practical in some circumstances
I've got a DE with a F3 with knackered electricals. The cost of repairs seems prohibitive given the risk it is beyond repair
Thabks for all the info. Really appreciate it
Posted 03 March 2018 - 02:19 AM
I guess they bred that third hand out of people once we got meters in our cameras, lol.
Doesn't the F3 only have one shutter speed without electrical? 1/60th if I remember correctly. I never tried using one with out a battery, might be kind of fun to play around with.
Posted 03 March 2018 - 02:42 AM
Given I've got the F2 no point really in me playing around with the F3 but I'll stick it on ebay at some point so somebody else can!
Posted 07 March 2018 - 02:05 PM
Dumb questions time:
1. Will this work exactly as the DP2 in terms of coupling with the "bunny ears" on my lenses; and
2. Out of interest, is the metering reading the aperture of the lens through the mount, or is it through this "coupling"?
As always any help gratefully received
Posted 07 March 2018 - 02:14 PM
DP-1, 2 and 3 all use the rabbit ears. This makes it possible to meter the light without stopping down the aperture. The DP-11 and 12 use the Ai ridge on the aperture ring, so you would need to flip the coupling out of the way and use stop-down metering with unmodified lenses from before 1977.
The stop-down actuator didn't get a linear relationship to the aperture until the Ai-S lenses. That is the big difference between Ai and Ai-S. This was changed to make it possible to control the aperture from the body with the FA.
Posted 08 March 2018 - 01:32 AM
I might have a chrome F2 going spare now with the DP2, if anybody is interested....
