Advantages to shooting raw?
Posted 20 October 2013 - 03:18 PM
Posted 20 October 2013 - 03:40 PM
The short answer is that raw files capture more detail as they have a higher bit depth (12-14 bits per color channel vs. 8 bits in jpeg files). In other words, raw files are capable of representing thousands of times as many colors as jpeg files. This lets you recover shadows/highlights much more effectively and gives you better gradients.
Raw files also include the original sensor data, which means you can apply any white balance profile you want after the fact. The desktop software that "develops" the raw file may also be able to do a better job of tweaking other parameters than the in-camera JPEG engine.
I shoot in RAW+ these days as this gives you the best of both worlds as long as you have enough memory. The JPEG file is what I use if little or no editing is required. On the other hand, if bigger adjustments need to be made, then I edit the raw file and use the jpeg file as a starting point/visual reference.
Posted 20 October 2013 - 04:28 PM
Posted 20 October 2013 - 05:01 PM
OK i did a couple of test shots, and downloaded them to my computer.
It would not open the RAW images until I downloaded CODEX off the net.
Posted 20 October 2013 - 05:22 PM
Posted 20 October 2013 - 05:25 PM
Posted 20 October 2013 - 06:15 PM
Posted 20 October 2013 - 07:58 PM
Once done editing in photoshop I can save the images as jpegs right?
Yes that's right.
I actually save the RAW file as a PS file, then Save As JPEG when I'm finished.
Posted 20 October 2013 - 08:41 PM
Hey Alden, shooting in JPEG when you have a camera that can shoot in raw, is starting by shooting yourself in the foot, as previous post have mentioned it has to do with the amount of information that is retained. Let's start by what a RAW file is, a RAW file is not a picture, it is a data file which records the output of the sensor. what you see on the camera is a JPEG thumbnail.
This data file allows you so many more possibilities since it has minimal compression compared to JPEG you won't get as much clipping of the colours in the darker range, if the RAW are sent to uncompressed you will have no lower clipping before the physical limits of the sensor, also most colour information is held in the darker range, thus its better to underexpose, than overexpose, as that was the method in the film days.
RAW files either store 12-bit/14-bit of colour information which means it allows for close to the 212 or 214 shades per the three colours that your camera uses RGB. that means that you have 4096 / 16384 shades per channel(colour) respectively. Additionally in most cameras you have the option between sRGB and Adobe RGB (1998), ALWAYS PICK THE LATTER.
Now why would you want so many colours, isn't going to be a excessive file... True, but whenever you bring anything into Ps it is destructive, you are killing pixels, and you can't do anything about it, so the more colours you have the better, and when you finish with an image always save in .psd after.
I would also add that the fact that when you shoot in RAW, if you use the wrong colour temperature you can correct it in Adobe Camera RAW, which is an amazing piece of software. Also using software like NIK from google you can do some awesome tone mappings (HDR from single image), or using neat you can remove most noise from your images without softening it too much.
I have many more disorganized thoughts, but that'll be for another time.
For viewing nikon .NEF files here is the link to the Nikon Codec
- scoobymax likes this
Posted 20 October 2013 - 11:30 PM
Sometimes I save my better work as TIFF files after editing the RAW file. Allows you to go back later and edit more if you need to, without loss of quality.
Posted 21 October 2013 - 03:20 AM
to K-9
I didn't understand. Why do you need TIFF if you can edit raw so many times as you want and you can come back to the original raw file at any time?
Posted 21 October 2013 - 04:38 AM
This is excellent information.
A lot I still don't completely understand, but I'm learning.
Why would I want to shoot RAW+? Why make a JPEG at the same time?
Just for convenience sake if I want to upload something to the internet fast?
Posted 21 October 2013 - 05:41 AM
That's assuming you always still have the original RAW file. Sometimes, I have too many photos and I need to remove some from my computer. If I have the TIFF, it's a better quality copy to reuse later than just a jpeg. Then, I don't have to start edits all over again if I wanted to reuse the RAW down the road.to K-9
#17
Posted 21 October 2013 - 08:29 AM
That is my understanding, though I am a recent convert to RAW. I am now a believer!
