I recently purchased a Nikon D3400 bundle package which came with the following lenses:
Posted 14 January 2018 - 02:02 PM
Posted 16 January 2018 - 11:05 AM
It sounds to me like you are only want to take one lens on your trip.
Given a choice, I would rather have the combined 18-55 and 70-300 rather than the 18-200. All lenses are a compromise in one way or another. The super zooms with an extended range from wide to tele (18-200, 18-300, etc) compromise on the quality compared to the shorter range zooms (18-55 / 70-300). Not suggesting the lenses produce poor images, rather that the image quality isn't as high with the super zooms as with the shorter zooms.
You don't indicate what types of shots you are hoping to capture on the trip, but unless you need the telephoto end, you would be better off with the 18-55 as the one lens you carry with you.
- Jerry_ likes this
Posted 16 January 2018 - 11:25 AM
The 18-200 will save you 220g compared to bringing both lenses. I don't feel that the loss in picture quality is worth that small saving.
That said, the 18-55 is very good optically, even if it doesn't feel as solidly built as the more expensive lenses.
Posted 17 January 2018 - 05:29 PM
here a good idea get use to the two lens you have. it will show where you need to go next for lenses. i still have both my 18-55 and 70-300 i use them based on what is need. i still use 18-55 since give me lower end reach since 35 and 50mm have longer reach. plus they are both good starter lens to learn from. after shoot for awhile you find what type of pictures you want to take and from that spot will lead to what your next lens should be.
Posted 18 January 2018 - 03:49 PM
Posted 05 February 2018 - 03:19 AM
Actually, it depends on what type of work you are up to. If you have an D 18-200 mm lens then I don't think you need an 18-55 mm lens
Also tagged with one or more of these keywords: d3400, 18-200mm, 18-55mm
Off-Topic Forums →
NikonForums.com Support and Suggestions →
Rotating videos on NX StudioStarted by EdgarGeo, 12 Aug 2023 d3400, video editing, nx studio and 2 more... |
Camera and Photo Help →
Technical Troubleshooting →
D3400 will not power upStarted by 08nikon03, 13 Jan 2021 d3400, no power |
Beginner Questions →
D3400 - how to take photos continuously over several hoursStarted by rawlins02, 19 Aug 2020 d3400 |
Downloading photosStarted by jackadog, 02 Jul 2020 d3400 |
D3400 External Monitor Options?Started by JamieHarris287, 27 May 2020 wifi, monitor, remote, control and 5 more... |
