Hi Finally got the d500. shooting milky way and trains. dawn to dusk. and some sports . Did some research and wanted to see what nikon lenses only you recommend some say 18-300 while others say several just wanted to see and hear some thoughts. Thanks Tom
What dx nikon lenses?
Posted 05 January 2018 - 10:50 PM
Posted 06 January 2018 - 12:57 AM
That depends on whether picture quality or convenience is more important. The greater the zoom range, the more compromises have been made to get that range.
Another factor is if you need the 16-18 mm range that only the 16-80 and 16-85 have of the normal zooms.
For me, the choice would be between the 16-80 and the 16-85, depending on funds available with an FX 70-300 VR to cover the rest of the range.
- TBonz, Ron and tomthetank like this
Posted 06 January 2018 - 02:32 AM
Posted 06 January 2018 - 11:07 AM
here another idea is there store or place near you that rents lens or will let you try the lens out. also what Merco_61 said is true. having longer range will effect photos too. i should know when trying to shoot soccer games at long range of my lens cause action pictures to look blurry
- tomthetank likes this
Posted 08 January 2018 - 02:03 PM
did some research and this is what i'm looking at not necessarily be able to purchase for the d 500. want to stick with nikon brand.
17-55 2.8
60mm 2.8
70-300 vrg full frame that you suggested
not sure about the 24mm, 105 fisheye
hearing mixed reviews on keh about used any one else that you know is trustworthy? Thanks for the help Tom
Posted 08 January 2018 - 02:16 PM
There are two things to remember about the 17-55. The first is that it is a very old lens, it was introduced together with the 4 MP D2H mid-year 2003 and the second is that it is heavy, it masses 755g, compared to the 16-80 @480. 275 g doesn't sound like much, but wait until you have carried it for half a day... It is still a good lens, but the 16-80 is both cheaper and less to carry.
The only US vendors for used equipment I have bought from are KEH and B&H, I have nothing but good experience from either.
Posted 08 January 2018 - 02:19 PM
I've bought used from both KEH and B&H without issues...all good there...
What kind of sports? Day or night? Indoor or outdoor?
I like the 16-80 / 16-85 recommendation along with the 17-55 as options on the wider end of the scale. The 70-300 is a good range for some sports but will be tough for indoor or night games...70-200 is your best starting point for a sports lens...It is very sharp and quite possibly my favorite lens...
You can also check borrowlenses.com or one of several gear rental sites and rent a lens to try out to see how it meets your needs in your hands...
- Merco_61, Ron and tomthetank like this
Posted 08 January 2018 - 02:27 PM
My idea behind going for the 16-80/70-300 combo is that you will then learn from experience what the limitations are and get more gear that solves problems for you, not what we tell you to get. They are both *very* good, capable tools even if more specialized lenses are better in some situations.
What use do you see for the 60? If you want it as a nice portrait lens with close-up capabilities, it is the correct tool but if you want to play with some real macro work, it is a bit short in focal length as the working distance gets so short. A third-party 90 or 100 mm macro lens or an old MicroNikkor 105/4 of any flavour will make life easier if you want to play @1:2 or so.
- TBonz and tomthetank like this
Posted 08 January 2018 - 02:43 PM
thanks , appreciate the help
Posted 08 January 2018 - 03:19 PM
looking to do railroad day and night , well dawn to dusk, some sports, milky way
want to have flexibility.
Posted 12 January 2018 - 08:01 PM
never had issue with keh. i have used filters and add parts also got a use 12-24 from them and its great no issue with it works like charm. if any you from keh does not work to your standers they will take it back.
17-55 2.8
60mm 2.8
Posted 16 January 2018 - 11:35 AM
Any movement at night and you are going to want at least f4 and probably f2.8...the 70-300 might be tough at times with the low light shooting, but other than that it is a great lens from the images I've seen...
