I do some night photography, primarily meteor showers and satellites. I have 2 problems.
1. I have had little success with the interval timer during meteor showers. I set it up for 20 or 30 exposures at 20 sec. intervals. It shoots 5-10 shots and stops. I go through the setup again with the same result. Getting ready to drive 2 hours for the Leonid shower next weekend and want to get this worked out. Any ideas?
2. Sometimes I set it up at home, f1.8, 30 sec. exposure with the interval timer and test it and it works. Then I drive 45 minutes to a very dark spot in the mountains, try to set up the interval timer and get the message "function not available with current settings." Yet it worked fine an hour before; is there a gremlin hiding in the mountains?
Any advice is appreciated.
CM
