Cleaning Image Sensor
Posted 28 September 2017 - 05:35 PM
Reading my manual it says only an Authorized Nikon Dealer can do it or the warranty is void. With Nikon that is a three week process. But I am not sure I want to tackle this task yet. Do some of you take your camera to a local camera shop to clean so you can get back almost the same day you drop it off?
Posted 28 September 2017 - 06:44 PM
I saw this the other day. If you're feeling adventurous - DIY.
Camera Sensor Cleaning Simplified! l Jansen Photo Expeditions
- Steve M likes this
Posted 28 September 2017 - 07:02 PM
Yes many of them type of videos on YouTube also. I think I just need to bite the bullet and get the stuff to do it.I saw this the other day. If you're feeling adventurous - DIY.
Not sure what size swab to buy. I think my sensor is 23.5 x 15.6 mm.
Posted 28 September 2017 - 10:03 PM
Here is what you need: https://www.bhphotov...a_Solution.html and https://www.bhphotov..._6x_Sensor.html if you want to use the Visible Dust system. The DX swabs are for both APS-C and DX sensors. The blue solution handles both oil and water contamination and works well with the green swabs.
Posted 29 September 2017 - 08:44 AM
Peter... do you like this over the Photographic Solutions stuff, and if so why?
Posted 29 September 2017 - 08:50 AM
Several years ago my favorite photo shop in my area closed down unexpectedly. Once or twice a year they would have an advertised cleaning day which included sensor cleaning. They charged for the sensor cleaning but did general check and cleaning for free - and all while you waited. They would do it any time but those days it was while you wait and less expensive...
After they closed down, I bought my own cleaning setup and have done it myself. It isn't hard even though it scares me every time! I definitely don't do it unless I have to ! I probably should, but I don't!
Posted 29 September 2017 - 09:01 AM
They are very similar in use and I have used both with good results. I am more familiar with the Visible Dust system today as that is what the local store has in stock. The sensor swabs don't work too well with the other solution as the evaporation rate differs a bit so one of the combinations can streak, I don't remember which. The important thing is to get one system and keep to that.
Posted 29 September 2017 - 05:59 PM
I ended up buying this last night out of haste. I am to get it tomorrow as I wanted something before Sunday. If for any reason I shouldn’t please tell me and I won’t use it. I can return at no cost and order as per your post. Recommended by a YouTube video.
https://www.amazon.c...0?ie=UTF8&psc=1
Posted 30 September 2017 - 07:37 AM
I haven't heard anything negative about this system, so go ahead and use it. As long as the solution and swabs are made for each other and tested together, which system you use is a matter of taste.
I will use but will switch to your system. I just have some really bad spots that I have to get rid of.
Thank you much for your help
Posted 30 September 2017 - 01:07 PM
He told me to do my sensor clean in the bathroom, after running the shower cold for a few minutes. This is to reduce any airborne dust in the room.
