Tethering solution to new MacBook Pro
apple macbookpro d5600 usb-c cameracontrolpro2
10 replies to this topic
amdizack
amdizack
  • 4 posts
I am in need of wizardry (or someone to share some knowledge) on tethering.
I have a new MacBook Pro running Sierra (10.12.5) and for the life of me, cannot get either the Apple Image Capture program or Camera Control Pro 2 to recognize when my D5600 is connected. I am using a Nikon supplied UC-E20 cable into a USB-C adapter then into my Mac. I have tried several different cables and even swapped the DSLR body. I have successfully tethered on my old Mac (w/o USB-C ports) without issues.
I know I could use wifi/bluetooth but really want a cable solution.
Can someone tell me if this is even supported or what I might be doing incorrectly? You'll be my hero...
Thanks!
  • 648 posts
Who's USB C to A adaptor are you using?
amdizack
amdizack
  • 4 posts
I've tried an Apple one and an Amazon one.  :wacko:
In addition to Scott's suggestion, what version of CCP do you run?
  • 648 posts
When plugged into the Mac, do you at least see photos on your camera in the Image Capture.app?
amdizack
amdizack
  • 4 posts
I am running 2.25.0.
Just to check that the adapter is compatible, does Image Capture see the camera? Does Transfer? If you are an Adobe user, does LR, and in that case, can you run tethered from LR?
amdizack
amdizack
  • 4 posts
Neither of the programs see the camera. The camera "sees" the cable plugged into it but none of the software does. Is there an easy way to verify the adapter is compatible? Apple nor Nikon are able to confirm either way...
Do you live close enough to an Apple store that you can bring the computer, apple adapter, cable and camera in? Showing things in person usually gets better results than trying phone support when there is no script for the phone jockey to follow.
  • 648 posts
I use the Apple adapter to connect my Nikon to the USB-C port on my phone for transfer to Google Photos... which works fine.
If you have a USB stick available, try plugging it into your Mac via the Apple adapter. If you're able to access that, I would guess this is an Apple driver issue.
  • 648 posts
Another thing to check would be to launch the System Information.app and click on 'USB' in the sidebar and look to see if the camera is listed under any of the devices/hubs.
Also tagged with one or more of these keywords: apple, macbookpro, d5600, usb-c, cameracontrolpro2
