Humidity
Posted 01 June 2017 - 07:53 PM
Now I'm looking for suggestions and best practices on how to best deal with the humid climate!
Posted 01 June 2017 - 08:55 PM
When I lived in cold, wet climes (I retreated to the desert so don't have that problem now) they said you should walk out of the house backwards with the camera under your parka. Now I am sure you don't wear a parka these days but maybe under your tee shirt??? You probably need to stock up on those little packets that draw moisture out of the air and put them in your camera bag. Good luck.
Posted 01 July 2017 - 06:46 PM
My alternate idea is to buy a film Nikon body and lens (a film camera should be very cheap) and keep it in your car or someplace that will expose it to the humid weather. That way you're not taking it out of your air conditioned home.
I recommend a Nikkormat or a Nikon N2000. The latter takes AAA batteries that last for years. I use an N2000 as the camera I always leave in my car trunk even when the temp gets to 125. Not a sophisticated camera but rugged. I used to use my Nikkormat when I needed to go out and take photos during dust- and sandstorms in Arizona. I'd leave my high tech cameras in the trunk and use the Nikkormat. Goo luck.
