D5300 Autofocus - Wildlife
d5300 autofocus
14 replies to this topic
austinkiker
austinkiker
  • 11 posts
Hello all,
When shooting wildlife I have my D5300 set to 39pts of focus (the most it offers - lots of BIF) and AF-C (continuous-servo).  I also use matrix metering.   I shoot 98% of the time in Manual mode so I want to ensure I have those autofocus and metering settings setup properly for wildlife.  Thoughts?
Thanks for your help,
Austin
Daniel
Daniel
  • 512 posts
Hello all,
Austin
I shoot in single focus point with AF-C.
  • 1,488 posts
So do I
  • 10,119 posts
And another vote for single-point AF-C, at least when I use AF at all.
I use center-weighted metering or even spot rather than matrix for predictability. As the metering bias with matrix depends on comparing to a database, you never know if the camera has identified the scene correctly. I don't like to let the camera computer decide things without telling me.
austinkiker
austinkiker
  • 11 posts
Thanks for your insight, folks.  I'll put that knowledge to the test and see what sort of results I get.  I'm excited to try this out.
Wayben
Wayben
  • 90 posts
  • LocationIowa
Single point AF-C and spot metering here too.  Fewer chances for the camera to make wrong choices.
austinkiker
austinkiker
  • 11 posts
Great, thank you.
  • 2,092 posts
When I use AF-C at all, I usually use single point AF-C. Having said that, I'll add that I've also used multiple point AF-C with some success. When it works, it's great. But you are turning a lot of control over to the camera.
Ditto with matrix metering. I usually use either center weighted (mostly) or spot (occasionally).
austinkiker
austinkiker
  • 11 posts
I'm going to throw a curve ball here.  I was sitting on a river bank photographing a Bald Eagle flying overhead on a sunny, clear day when these three guys popped their heads up, curiously watching me (see photograph).  As you more able photographers than myself know, it is tough to switch settings fast enough to keep up with the drastic and sudden changes in wildlife.  I swung my camera down from photographing a bright blue sky and single subject (eagle) to murky waters and three subjects.  Let's forget the need to change iso, shutter speed etc, and stay focused on the points of focus and metering.  What would you use to photograph these three otters, keeping in mind they are not stagnant objects.  They were bobbing their heads in and out of the water etc.  You might notice the otter standing tall in the background has a bit of a blur to him, there was a limb in the way.
  • 10,119 posts
I had to think about how I do things in such a situation. As I use center-weighted metering, I would probably be @ about +1.3 steps e.c for the eagle and want to be @ -0.3 for the otters because of the murky water. This changing of e.c. is pretty instinctive and I usually flip the wheel with my thumb as I move the camera. I seldom leave aperture priority and AutoISO when shooting wildlife. I have the shutter threshold set either to 1/the focal length or ~1/500 depending on what I think I will see. If I had a later body, I would usually use the auto threshold speed as that gives 1/fl. This isn't an option on the D700, though. I usually use AF-C with single-point and rear-button activation, and wouldn't change for any of these situations.
austinkiker
austinkiker
  • 11 posts
Do you stay at single focus point?
Nevermind i read through your post again and saw that, yes, you stay in a single focus point
  • 10,119 posts
Usually, yes. There are situations where the follow-focus modes work well, but the single-point AF won't suddenly decide that something in the background looks more like what I locked focus on, jump away from the subject and lock on something different than what I intended. When I have used D4 and D810 bodies, I have used the multi-point modes much more as they are much more refined than the old AF system in my equally old bodies.
austinkiker
austinkiker
  • 11 posts
How does your depth of field turn out on single focus? If I have 3 subjects in my viewfinder, as with the otter photo, will single focus be able to lock onto all three subjects that are in varying degrees of depth?
Of course I will experiment and find out what works best for me but I am all about picking others brains and gaining knowledge as much as possible. Thank you so much for your insight and time.
  • 10,119 posts
The AF doesn't take DOF into account. You have to decide yourself where you want the focus plane. The DOF is dependent on the chosen aperture. With practice, you can judge the approximate DOF by closing down the aperture with the DOF preview button. This is easier with the better finders found in the D7xxx upwards bodies but it is doable with the D5xxx series as well. It gets easier to get a predictable DOF the more you use your camera and lens as you learn to visualize what the DOF will be without stopping down to check.
Wayben
Wayben
  • 90 posts
  • LocationIowa
I would still use AF-C and single point, then adjust aperture for DOF.  I'm pretty much guessing a the right aperture, but I like me guessing rather than the camera.
Also tagged with one or more of these keywords: d5300, autofocus
