Posted 10 March 2017 - 08:39 PM
Anyone have experience using a monopod with feet vs a full tripod? I ask as I have used a mono without feet and found it only somewhat useful. But have run into several venues where monopod is OK but tripod banned.
Posted 11 March 2017 - 01:34 AM
A monopod is overall a less stable basis than a tripod, but if it is the only option allowed then it is still often an improvement to handheld in low light situations.
A monopod with feet is slightly better than one without, provided you are standing on a solid flat ground. However it also depends on the quality of the build of the monopod.
Posted 11 March 2017 - 02:27 AM
The problem with most monopods with feet is that they won't let you get the maximum stability a monopod offers unless you always use it uphill as that stability comes from creating an isosceles triangle with the ground as the short leg. With the monopod vertical, you will always sway slightly when you use it.
Posted 11 March 2017 - 12:10 PM
I actually have one of these beasts and rarely use the feet. After awhile they tend to be a bit of a hassle. However, in certain situations, they can and do come in handy. Just be sure you get a good brand such as the Manfrotto.
