Hi, I selected the clean image sensor "clean now" on my d810 a few hours ago and now none of the camera functions work. The green light comes on briefly when I try any function.
Does "clean now" take a long time, or is there something else going on?
d810 "Clean Now" - camera appears to be frozen
Started by Splask, Feb 18 2017 08:50 AM
Posted 18 February 2017 - 08:50 AM
Posted 20 February 2017 - 01:29 PM
The 'clean image sensor' > 'clean now' should take about 5 seconds after you pressed ok.
The 'lift the mirror for cleaning' will require the shutter to be pressed for lifting the mirror. The mirror will stay up until you press the shutter again or switch off the camera.
If the camera is staying in this mode I would suggest to switch off the camera, wait 1 minute and then switching it on again. I would also suggest to recharge your camera's battery before repeating the operation.
