d5200 Flash Options
d5200 flash speedlight sb700 options menu overexposure ttl
Diesel Dave
Diesel Dave
Hi Folks,
I'm trying to use my new SB700 speedlight off-camera. I won't be buying a radio trigger, so I have to use my on-camera flash as a trigger. 1/200 is the fastest shutter speed available when using on-camera flash. The on-camera flash is overpowering the subject, that is i'm getting sever over-exposure.
Looking at tutorials, I see instructors going to Menu Option e1 "Flash control for built in flash". A number of options are available, including using on-camera flash in trigger only mode (is this the same as "command mode"). In this mode, the on-camera flash emits only enough light to trigger the remote flash, but not enough to have much effect on the exposure. However, when I go to the same sub-menu (e1: Flash control for built-in flash). I have only two options: TTL or Manual. No matter which setting I use, on-camera flash is washing out my subject.
In short, how can I shoot with my d5200 using the sb700 remotely without triggering on-camera flash? Any help is greatly appreciated.
Best, Diesel Dave
  • 2,261 posts
I've never used this but it is, apparently, Nikon's solution to your problem.
Nikon SG-3IR Panel
Nikon_4905_SG_3IR_IR_Panel_for_123296026
You can use the SB-700 in manual with the SU-4 mode to trigger it, but the D5200 doesn't support using the pop-up flash as master for CLS. If the distance you need isn't too great, wired off-camera flash works well, and a SC-29 cable or a copy isn't *that* expensive. If you stumble upon a used SU-800, it will work with CLS, just like if you had a D7x00 upwards body. There are apparently TTL radio triggers on ebay that work well and don't break the bank, but I haven't used any of them as I tend to use either IR-triggered CLS or a radio link for my manual studio strobes.
Also tagged with one or more of these keywords: d5200, flash, speedlight, sb700, options, menu, overexposure, ttl
