Need help with a Nikon F50 film camera!
hannamarley
hannamarley
I have a problem with my camera in which sometimes I cannot find the Program Settings as an option. I turn the camera on, switch to advanced mode, but can only get either Manuel pr Auto...
I can't focus the camera at all right now, so I can't take any pictures that aren't out of focus. Any ideas as to why this might be happening and how to fix it?
Thank you SO much!
  • 6,970 posts
M or A mode only sounds like the body can't identify that there is a chip present in the lens, so it reverts to Ai functionality.
No focus sounds like it is in Manual focus mode, but if the AF coupling isn't retracted, the focusing ring will be locked just like if it was in AF.
Both these symptoms point towards either dirty contacts or a broken or loose contact block in either body or lens. It could be as easy as the lens not being twisted fully into the locked position.
What happens if you set the focus selector switch to M? Are you able to focus manually then? Do you have another lens to try?
hannamarley
hannamarley
So, this is what happens with two different lens. With one lens, I can switch only to M or A, but neither focuses at all - the lens is firmly locked into place.
With the other lens, I can switch to M or A, but not to any other options - the other options when I press the program button, do not appear. :(  With A or M though, I can focus.
