SB-5000 Speedlight battery issue
sb-5000 speedlight
Wreckdiver
Wreckdiver
  • LocationChippenham
I recently purchased an SB-5000 Speedlight and have noticed that when switched off but with the battery left in it will discharge over around 12 hours. Has anyone who has got this Speedlight noticed this? I contacted Nikon who thought it might not be right but couldn't give me a definitive reply. Before I return it I would like to try and ascertain if this is a problem or not. I always remove any battery when not in use but if the unit is faulty then I'll get it replaced.
Thanks, Steve
dcbear78
dcbear78
  • 701 posts
I don't have that particular speed light but my SB700 can go months between uses and batteries are fine. I'm using Eneloops which are supposed to be very good at retaining charge whether that makes a difference I'm not sure.
roger_rob13
roger_rob13
  • 43 posts
I have 2 SB800'S. Last time I used one was back in August, on vacation. Put one on the camera last night for a party and it still had 75% of charge left. Hope this helps. Sounds like yours has a fault somewhere.
Sent from my SM-G903F using Tapatalk
Wayben
Wayben
  • 100 posts
  • LocationIowa
I bought an  SB-5000 about a month ago and it has been sitting with batteries installed.  I just checked it and they are still charged.  Sounds like yours has issues.
Same for both my SB600 and SB910...I go months without using and batteries in the units.  Still plenty of charge left when I check them...
Wreckdiver
Wreckdiver
My SB-5000 turned out to be faulty. I measured 350mA being drawn whilst it was switched off! Also, it was missing its Bounce card - how that happened I've no idea.
Anyway, I now have a replacement which is perfect.
Thanks to all for your comments.
Steve
Also tagged with one or more of these keywords: sb-5000, speedlight
