Please Critique. First attempt indoors with D70's onboard flash.
d70s onboard flash
7 replies to this topic
Tony
Tony
  • 2,517 posts
  • LocationBeaverton, Oregon
I was really after the proper composition and took several shots from different angles and distances.  I felt that this was the best out of all the attempts.  Basically, I still feel there is something lacking, perhaps a bunch of grapes in front of the plate would have added more interest and an overall better photograph.  I believe the exposure turned out to be acceptable at best after trying different distances using the onboard flash.  Typically I use my SB-24 when needed however, I wanted to also see how the onboard flash would perform.  Please feel free to offer any comments/suggestions/solutions.
Many thanks for viewing.
Tony
D70 body with AFNikkor 28~105mm f/3.5~4.5D IF AF Lens.
1/60s, f4.5, used onboard flash and Pattern Metering Mode with a Focal Length of 85mm. ISO 200.
  • 1,527 posts
Tony, there must have been a problem when you tried to attach the picture.
leighgion
leighgion
  • 167 posts
  • LocationMadrid
Popup flash never looks fantastic. I think you did better than many, but still have the usual problems with hard shadows when there's a wall so close behind.
Aesthetically speaking.. I think the problem is that you seem focused on just practicing the technical aspects and don't seem to have a particular notion of what kind of image you wanted to make.
Tony
Tony
  • 2,517 posts
I thank you a lot for your input.
Rgds,
Tony
etphoto
etphoto
  • 229 posts
  • LocationCincinnati
Critique? Shadows distract in the image. What light source was there besides the flash?
Twitter: @PhotographyET
Tony
Tony
  • 2,517 posts
Just the overhead florescent lighting.  There is one obvious shadow, however when shooting a subject that is placed higher than I can reach, it is to be expected.  The shadow isn't all that bad, however, I should learn how to avoid shadows.
Thanks ETPhoto for your input.  Tony
Tony
Tony
  • 2,517 posts
Hi Jerry,
I am not certain about what you mean.  Will you please elaborate?  Thanks, Tony
  • 1,527 posts
Hi Jerry,
Tony,
When I posted that message on 30/9, there was no picture shown.
Now there is.
Also tagged with one or more of these keywords: d70s, onboard, flash
