Hi. I have a question for you. What is the main in creation of picture: shooting or post-processing? How many photos did you post on web without post-processing? As I know almost all great photos that are made nowadays are the result of post-processing. What do you think about it?
Shooting and post-processing
Posted 08 October 2013 - 02:58 PM
Posted 08 October 2013 - 04:08 PM
Posted 08 October 2013 - 04:37 PM
I'm with Scoobymax, I post process as little as possible.. when possible. A little White Balance correction, tweak the contrast, that sort of thing. That said I honestly believe what you do after the shot is just as important as setting the shot up right in camera. Learn to use a good program... get good at using it.... just don't over use it.
Posted 08 October 2013 - 11:26 PM
not that much the art of photography is in the picture taking not by altering the image
Posted 09 October 2013 - 09:38 AM
Don't actual digital camera already doing 'internal sensor processing' before delivering the picture in RAW
(i know that in JPG they do process a lot)
Posted 10 October 2013 - 06:59 AM
And how many photos you published (per 10 of your photos for example) without ANY postprocessing?
Posted 10 October 2013 - 08:09 AM
I think RAW delivers the images as the camera saw it without any internal post processing
Now that I have the D7100, more than I used too
Posted 10 October 2013 - 08:20 AM
Can I see your photos without postprocessing?
And what about raw me too I think so. Raw is the format is the image without internal postprocessing, this format save as many information on your photo, as your camera can see.
Posted 10 October 2013 - 12:39 PM
Posted 10 October 2013 - 01:39 PM
Posted 10 October 2013 - 05:38 PM
- ashchuckton likes this
Posted 11 October 2013 - 01:02 PM
Posted 16 October 2013 - 07:19 PM
Over the past 10 years in my job, I have post-processed a huge number of photos. Some photos start out bad and ended up better after processing. The best photos I have seen don't need hardly any post-processing.
When shooting my own photos, I always shoot in RAW format, and I try to set up the camera settings properly (THIS skill I am still learning!) so that my photo turns out beautiful and sharp without having to make hardly any post-processing adjustments.
The more an image is worked on, the more "muddy" it can get.
Posted 16 October 2013 - 08:21 PM
White balance - tweaked a tiny bit if needed
Color saturation - usually enhanced slightly; I feel doing this is just the equivalent of simply buying higher saturated color film in the film days; it wasn't cheating then! I may also tweak the color if I don't think it quite matched the true color of the scene I shot.
Sharpness - I barely tweak it; I know a lot of people do, but I often wonder if they're just not using sharp lenses or focusing correctly, because I usually find my pics sharp enough and don't need any more.
Exposure - only tweaked slightly if needed; I firmly believe that meters on film cameras were better than DSLR meters. I could spot meter off a gray card with a film SLR, take 200 slides, and have 198 of them come out perfectly exposed. I'd say the number of perfectly exposed digital shots if I did the same is less, more like 178 out of 200.
Cropping - this is probably my most used post processing tool. Probably a lot has to do with my D700 not showing 100% field of view in the viewfinder. Helps a lot when needing to straighten a horizon or other objects in the scene.
Iris enhancing, teeth whitening, and skin softening I do use on occasion for my best portraits. Spot correction also for small edits. Nothing overboard that would become evident in the final shot.
I rarely use Photoshop or cloning or background changes, or anything major like that.
Posted 21 October 2013 - 09:57 PM
The main reason I shoot RAW is for the flexibility it allows in Photoshop.
But I won't attempt to turn a bad picture into a good one.
The best results are always achieved if you start with a nice sharp, and reasonably exposed image.
My basic adjustments would be White Balance, and Cropping,.
Then I re-size for the net, adjust Levels, Unsharp Mask, add a watermark, then save as JPEG.
The whole process takes between 10 - 30 minutes.
Posted 22 October 2013 - 01:01 AM
As just a photo hobbiest i try and not post process too much other than what most are saying above, white balance tweeks etc. But, i do love mucking about with photos as well, changing colours etc just to see if i can get something a bit un-natural but pleasing to the eye. To me my Elements 11 is a toy that like all toys, needs played with
