Nikon D5300 wifi
Posted 08 September 2016 - 02:20 PM
Regards
Posted 05 March 2017 - 08:05 AM
Posted 23 April 2017 - 11:36 AM
Posted 26 January 2018 - 06:27 AM
Posted 28 January 2018 - 08:30 AM
got to make sure your in area that has wifi if not camera and phone will not read each other. i found that out. once you find how to get both to read each other your good to go. just have to recall how you got them to read each other. only issue i had with was with this issue. last year i took pictures of local hooters girls for Halloween instead of doing right away and taking card out and putting on laptop. i did wifi thing. found out it took my full jpg and full raw files and crop them down to really low resolution picture that looked way to bad. since i could compare quality of them. did not like way photo or camera made my pictures get crop down to really bad resolution pictures i showed people at store and buddies and we are not sure why it happen this way. so for now on will only take off memory card to laptop for pictures. so will have to wait in till i get camera body with snap bridge to see if works better or not.
Posted 14 February 2018 - 09:20 AM
Yes in an area with wifi at every try. I'm pretty good technology. I think it's an issue from Nikon they will probably lose me forever and switch family. That's unfortunate, cause I was with Nikon from the beginning.
Posted 14 February 2018 - 10:03 AM
As the wifi connection is peer-to-peer and not infrastructure, whether you are in an area with wifi or not is immaterial.
When using an android device, the instructions on page 169 in the manual work. WPS pairing is, by far, the most stable of the options.
If you use a device of the fruity persuasion, the instructions on page 171 should be foolproof.
- Steve M likes this
Posted 22 October 2022 - 08:30 AM
I installed the Nikon Wireless Mobile Utility on both the iPhone and in the tablet.
For each I followed the manual pp 217 through 220, and If ollowed the instructions for setting up the camera ("enable").
I get a continuous message "waiting for connection". But no connection us established and the "smart device" (both of them) do not connect to the camera.
The app tells me to check the smart device network settings...
Again, I tried this in both following the instructions.
Any ideas? Thank you. Elya
