Posted 25 August 2016 - 08:23 PM
Posted 26 August 2016 - 02:06 PM
The D90 and the D7100 are both DX bodies, just like the D5300. To go full-frame, you will have to go up to the D6x0, D7x0 or D8x0 series'. The D5300 is a nice body as long as you don't want to use screw-drive lenses and aren't too frustrated by the dimmer pentamirror finder compared to the pentaprism finders in the prosumer or better class bodies. The buffer isn't the largest, but the same goes for most of the affordable bodies.
If you want to get into FX relatively cheap, D700 bodies aren't too expensive used. The switch can cost a fair bit even if the body is cheap, depending on what lenses you have and whether they are FX or DX.
Posted 28 August 2016 - 06:02 PM
There are only two classes of DSLRs. DX (what you have) and FX. Both the D90 and the D7100 are DX cameras, as is your D5300. I've never used a D5300 but I'm pretty sure that it has a better sensor than the D90 so I would forget that camera right off the bat.
What you're calling 'Full Sensor' is, I suspect, what Nikon calls FX or Full Frame. As Peter said, that's quite a jump from your D5300 especially if you have a fair number of DX format lenses. To take advantage of the FX sensor you're going to need FX lenses. Otherwise there's really no point in buying a new (or used) FX body. If you do have some FX lenses then the D610 is being (or soon will be) heavily discounted. Nikon wants to move these cameras out of inventory to, I'm guessing, make room for a new model. The D610, btw, is an excellent camera.
Posted 29 August 2016 - 03:30 AM
For wild-life photography you would use a Telephoto lens for most subjects, the Full-Frame sensor means using much longer focal length lenses.
For wide-angle photography- the full frame sensor is an advantage.
Opinion- stick with the D5300 for a while. If there is something not being delivered, look for the larger sensor. Remember that many Pro photographers waited a long time to get the new professional DX format camera. Many have stuck with DX bodies and lenses.
- Ron likes this
Posted 29 August 2016 - 08:20 AM
I would tend to agree with Brian...no need to upgrade unless you are being limited by your camera body...I would put my money into the best glass (lenses) that you can get and buy non-DX lenses (they work with DX bodies but are not designated DX in the lens name) so you are ready to upgrade to full frame down the road if you decide to do that.
Posted 17 September 2016 - 01:47 PM
Put me down as another vote to stick with your D5300 for now. Are there better camera bodies? Yes, but until you have a very clear reason to feel limited by your current camera, it's a waste of cash to upgrade just on the vague idea that newer is going to make things better. Money's better spent on lenses, or just on supporting time to develop your photography.
Also tagged with one or more of these keywords: d90 d7100, d5300
Camera and Photo Help →
Technical Troubleshooting →
Neewer Speedlite FlashStarted by 56up, 11 Apr 2024 d5300, syncing, speedlite |
Beginner Questions →
D5300 - No live view on External MonitorStarted by nikonkenjee, 24 Nov 2021 d5300, external monitor and 1 more... |
Dropped CameraStarted by Capybara, 15 Jan 2021 d5300 |
D5300 "Metering Malfunction Detected"Started by mikepowell, 03 Jul 2020 d5300, metering malfunction |
Lenses and Accessories →
Nikon Lens Discussion →
Good superzoom/telephoto lens for Nikon D5300?Started by robc009, 29 Dec 2019 nikon, d5300, zoom, superzoom and 4 more... |
