Hi,
I bought a 200-500 mm lens a couple of months ago. I've used it a few times since then and now twice I've had a situation whereby the camera (D750) completely locks up while I'm shooting. Nothing on the camera will function. I can't view the menu, change any settings, playback anything I already shot on the card, or even turn the camera off. I move the lever to the off position, but the camera doesn't shut off. Unscrewing the lens and putting it back on did nothing. The only recourse is to remove the camera battery and put it back in. The battery was still 3/4 charged, the memory cards I use are Sandisk Extreme 32G and they are the high speed ones. I was doing continuous shooting at the time in Aperature priority mode. This very frustrating as I missed quite a few shots until I figured out how to resolve the issue. I've never had this happen with any other lens. I've read a few other accounts of others having this issue. Not sure if it is the lens, the camera or the combination of the two. I have used the lens on my D7100 and not run into the problem as of yet.
Does anyone know what is causing this or how to resolve?
