I'm attaching a .pdf showing 4 shots of a rattlesnake in an exhibit. Not great shots, but no matter. Each was taken at f/8, 1/160, manual with auto ISO, 8mm center weighted. The 4 shots appear nearly identical in subject and background. But ISO bumps up from 3600 to 4000, then 8000 , then 12800 (a range of two stops). It seems like the initial exposure should have been sufficient (ISO 3600). Naturally, I don't want to be jacking ISO higher than I need to. I'm thinking of either going to a 12mm CW or matrix with exposure compensation. Does anyone see in these photos what is causing ISO to rise? Am I just getting the same instability that often occurs with spot metering?
Need some help explaining variation in exposures
Posted 15 June 2016 - 09:08 PM
Posted 15 June 2016 - 10:57 PM
I suspect that you might be right. The heavily centerweighted metering is more like a semi-spot and must be used carefully.
Another factor is how the terrarium was lit. Under incandescent lighting, exactly where in the on-off cycle the exposure is locked can make a big difference. If you switch Auto-ISO off in such conditions, the meter will even things out. 1/160 can be high enough to get erratic exposure under some light sources anyway as the light cycles so you need at least 1/60 if not longer to get a full cycle.
Posted 16 June 2016 - 07:55 AM
I agree with Merco on the light cycle, but I also see that from the lowest to the highest ISO, the center area in the image gets progressively darker so it is quite possible that a wider center-weighted area might have helped. You should also be able to limit the highest ISO if need be.
