Sorry, I didnt read that properly, ok for buffer, it makes sense, thanks.
Yet I strongly doubt I'll use this feature much, even when birding.
Once again, sorry for all the questions, I have a flight this wednesday, 20:45 hrs, I will read manual and tips & technique during the flight, atleast thats my plan.
A)
I just googled "D800E AF mode", and got to Kenrockwell, seems it is about the AFS-S, AFS-C; single, D9 D21, D51, and basicly its the 4 modes within AF-C I'd like to be able to swap between, I will definantly give it a try as soon as possible as for the front wheel, I only used the 'rear' which swapped betweeen AFS-S and AFS-C D51.
The other thing I meant, is if its possible to get 'all the points' in your selected mode shown in the viewfinder, hence; So your not in doubt on which 'D' you've picked....
I was hoping it would have a feature in D9 of which when you are selecting where in the viewfinder, the center would be red square, the others gray(or such), and once you press the shutter or AF-ON, it would turn red in the focus point camera selects.
C)
The body has a AF-motor, and all my lenses have AF-motor as well, will it ALWAYS select the lens? This is much faster in all cases, so it would be nice if I can make sure its not using the cameras...
D)
My Tamron 70-200 F2.8 seems to have AF-Finetune at +16, isnt that extraordinary high? I made a huge mistake, as I was using AFS-C when testing... - I only had a very few min...
I am pretty confident AFS-S is the no brainer choice for AF-finetuning.
E)
As for pure speed read/write
Does clone CF and SD boost performance/speed over just using overflow? RAW on CF, JPEG on SD I pressume gives best performance.
Note/Comment:
Compared to my D5200, I really appreciate that the battery drain is HONEST, the D5200 it shows 100% full untill perhaps 10% left on battery, while D800E keeps decreasing little by little - however, I am shocked that 100-150 picture with VC (VR) off on my Tamron, has drained it close to 50%, but I guess that is due it being 2 years old - the battery that is.
Coment 2:
I made another setup failure... Makes no sense doing uncompressed for video 1080p.... Which one would you guys recomend? - Also note, this I wont use much, the cam isnt build for the purpose.
