Need explanation of D500 1.3x crop
d500 1.3x crop
6 replies to this topic
DocPit
DocPit
  • 47 posts
If I'm understanding it correctly, just like a DX sensor "crops" an image relative to an FX sensor, the D500 offers a 1.3x crop mode, which, in effect, crops the DX sensor.  So, if I were to shoot with a lens that was 600mm on an FX body, putting that lens on a compatible DX camera gives me the equivalent of 900mm, and using 1.3x crop on the D500 provides the equivalent of 1170mm.  Is that correct?
  • 10,588 posts
More or less... You get the field of view of the 1170 mm lens on FX, but because you aren't as far away you don't get the compressed perspective or the shallow depth of field of the longer lens on the larger format.
mikew
mikew
  • 798 posts
  • LocationNorth East Lincs
To be honest IMO there is little benefit if any to using the 1.3 crop much better done on the PC later,with the small buffer on the D7O/D7100 reduced file size may have helped with FPS but not much.
  • 10,588 posts
The problem with cropping in camera is the loss of control. If you learn how an image cropped for maximum reach looks in the finder, you can recompose slightly after the fact. If you use the 1.3 crop you give up that freedom.
DocPit
DocPit
  • 47 posts
Basically, I'm thinking that, for those of us who shoot with long lenses, the 1.3x crop could substitute for a telextender, allowing that there are trade-offs.  So, for example, my 600mm (FX) / 900mm (DX) lens would be equivalent to 1170mm DX with 1.3 crop vs. 1260mm with a 1.4 telextender.  Using the 1.3 crop, I would not lose an f/stop, I might be able to shoot at a higher ISO, and I would not be placing more glass between the lens and the sensor; however, I would be reducing my magnification (1170mm vs. 1260mm) and I would be losing sensor pixels (24x16 vs.  ~ 18.5x12.3). Does that make sense?
  • 1,524 posts
That seems correct to me. If you accept that with an 1.3 crop you will only use about 60% of the available pixels (still better than having the 1.5 crop from FX to DX, which results to 44% of the pixels being used). Now, the story is nowadays no longer about the number of pixels, but still it will make a difference for larger prints.
However, as mikew pointed out: when you crop in post processing all the above applies also, but you have extra margins to reframe the cropped area.
  • 10,588 posts
You will have to remember that when you crop (in post or with the 1.3 crop doesn't matter), the larger magnification will lead to more prominent noise patterns and a lower DR. There are situations when those factors get worse than when raising ISO to compensate for a TC. The larger magnification can also make atmospheric haze more prominent than if you used a TC.
Also tagged with one or more of these keywords: d500, 1.3x crop
