So I took 979 shots yesterday and would like to batch process the RAW files. Would like to include saturation, contrast levels adjustments with the final conversion to jpeg format. I know how to do this with NX2 but not with my Nikon D750 camera because NX2 does not support the RAW files from this camera. Any suggestions on how to perform this or program to use would be appreciated.
Batch Processing recommendations or advice
Posted 10 November 2015 - 02:33 PM
Posted 10 November 2015 - 03:20 PM
This type of batch basework is as easy in NX-D as it was in NX2.
- Do your adjustments and press cmd+shift+c on a mac (probably ctrl+shift+c on a windows box).
- Select the files you want to apply your copied adjustments to and press cmd+shift+v.
- Fine tune all files one by one as necessary.
- Select all files you want to export.
- Press cmd+e to start the export routine, adjust your export parameters and start the export.
- Done
LR 5.7 and later and PS CS6 and later if fully updated support the NEF files from the D750 if you have Adobe software available.
I am still learning NX-D, but I am impressed with how the program renders raw files from all the Nikon bodies I have experimented with. The UI isn't the mose intuitive I have used, but when you find everything it is reasonably quick to use.
Posted 11 November 2015 - 03:08 AM
In lightroom, you can process one image, copy the settings or make them a preset, then use them for the rest of your images pretty easily.
Posted 11 November 2015 - 12:41 PM
Yeah, ditto. For me, Lightroom is the way to go. It's amazing how much you can do with this application. And, it's designed to automate just about any process from import to export...and everything in between.
Posted 15 November 2015 - 11:53 PM
I used NX-D to batch process my photos and it worked well. Thanks Merco and everyone for advise and help.
