Help! Lense advice needed
lense advice tamron sigma nikon
bani12
bani12
  • 233 posts
  • LocationLjubljana
Hi!
I need some advice for my future lenses. I currently have d750 and Tamron 24-70, so I need something at the wider end, something at the tele end and a fast 50mm prime.
Which one would you suggest?
Nikon AF-S 16-35 mm f/4 G ED VR or Nikon 18-35 mm f/3,5-4,5G ED? I like using filters so 14-24 is out of the question, I think. Or should I go for the new 20mm 1.8 instead?
Tele:
Nikon AF-S 70-200 mm f/2.8G ED VR II or Tamron SP 70-200 mm F/2,8 VC USD? I would like to know If I can use teleconverter on Tamron If I decide to buy it? Price difference between the two is huge here (around 700 Euros).
Prime:
Sigma 50 F/1,4 DG HSM Art or Nikon 50 mm AF-S F/1,4 G? I tried both and Sigma was sharper wide open and had less CA, but the Nikon is much cheaper and much lighter.
Thank you all for your advice!
Urban
  • 10,587 posts
TheTamron has the added advantage of using the same filter diameter as your 24-70... The Nikkor uses 77 mm. You can use third-party TC-s with the Tamron, I don't think the Nikon converters work but I haven't tried the combination. With the saved 700€, you can take the step up to the 17-35/2.8 instead of the 16-35. I don't personally like the 18-35 as I find it unbalanced, at least on the D700.
bani12
bani12
  • 233 posts
  • LocationLjubljana
Hi Peter!
Thank you for your reply and advice. I will take a look at the 17-35/2.8. I hope I can find it locally because I would love to try it before I buy it.
Which third-party TC would you recommend?
Urban
  • 10,587 posts
Both Kenko and Sigma have a good reputation. They are not quite as good as the TC14, TC17 and TC20, but they work with all lenses as they don't have a protruding front element.
bani12
bani12
  • 233 posts
  • LocationLjubljana
I just saw that our local shop sells Kenko TC. I will try both and see what fits me best.
Thank you for the advice, I appreciate it.
Urban
Also tagged with one or more of these keywords: lense, advice, tamron, sigma, nikon
