Unable to White Balance using Measure option.
white balance d5300 led aquarium blue lights
10 replies to this topic
Nalchadz
Nalchadz
  • 5 posts
  • LocationUnites States, Burbank, CA
Hello Everyone,  recently I decided to purchase a DSLR camera to take pictures of my salt water aquarium.  The aquarium lights are mostly Blue LED's and White LED's.  I have been trying to do a white balance using a white balance card from a local photography shop but the camera keeps telling me that it was unable to do a white balance.  I can use the card outside of the fish tank under different lighting and everything works just fine.  Am I doing something wrong? Is there a better way to do a white balance.  My pictures do not come out nice if on Auto White Balance or even if I chose any of the other pre-set options.  The lights are 20,000 Kelvin.
Camera: Nikon D5300
Lens: Nikon 70-300 VR, Micro 85mm VR, and 18-55 VR.
Adam
Adam
    Nikon Forums Staff
  • Administrators
  • 1,241 posts
The white balance card has to appear gray.  If there isn't enough light, it will fool the camera and thus have no effect.
I would recommend shooting in RAW, as this will give you complete control over the white balance in post-processing :)
greenwing
greenwing
  • 293 posts
  • LocationWest Yorkshire, UK
20000 K sounds very high. The D7100 manual (first one I opened - check yours for what your camera can do), in the specifications section under white balance, says "choose color temperature (2500 K - 10000 K)", so 20000 K is well out of the manually-selectable range, presumably out of the Auto range too.
Maybe you can shoot RAW and adjust in post processing.
Chris
  • 3,297 posts
I agree...I would manually set to the highest temp (probably 10000) and see what it gives you.  If it still isn't quite right, shoot RAW to see what you can do in post processing.
Nalchadz
Nalchadz
  • 5 posts
Thanks for your response everyone.  The D5300 does not have an option to change to a different K.  I did some post processing using RAW image and they are much better however I am still not able to get the natural look.
Nalchadz
Nalchadz
  • 5 posts
When using RAW mode, what settings should I use on the camera?  For instance, should I be in manual mode or auto? Should ISO be low or high?  do any of these settings matter if shooting RAW image?
Thank you!
Eagles1181
Eagles1181
  • 532 posts
  • LocationTexas
Shoot the way you normally would.
Focus and light still matter.  Although light is adjustable, the less you mess with light post processing the better.  Color shift (B&W conversions, white balance, ect...) don't matter and in fact are not even recorded in the file.
Eagle
Nalchadz
Nalchadz
  • 5 posts
Eagle
Okay, so as long as object in this case the fish is in focus and my ISO is high enough then I won't need to mess with the other settings.  Is that correct?
Eagles1181
Eagles1181
  • 532 posts
  • LocationTexas
Are you planning on shooting in auto?  If so, than ISO in controlled by the camera as well.  If shooting in manual, you need to worry about all three aspects of the exposure triangle (speed, aperture and ISO).
Eagle
Nalchadz
Nalchadz
  • 5 posts
Eagle
I am using Manual mode.  I've been doing some reading and it looks like there are tons of people who are having the same issue with shooting fish/corals under LED lighting.  Just need to keep changing the ISO, Aperture and Speed till I get the right combo I guess.
Eagles1181
Eagles1181
  • 532 posts
  • LocationTexas
LED is a strange lighting system as far as color goes.  You might try putting the white balance on AUTO and taking some test shots to see what the camera comes up with.
Eagle
Also tagged with one or more of these keywords: white balance, d5300, led, aquarium, blue lights
