Tri-Pod Head for Telephoto Lens
15 replies to this topic
Daniel
Daniel
  • 512 posts
I am wanting to buy a new tri-pod head for my telephoto lenses. I saw some guys with them last year while photographing wildlife. There tri-pod heads enabled them to pivot the lens and camera around quite easily without have to tighten and loosen any dials on there tri-pods. As well when they released or let go of there their cameras, the camera and lens would level itself out automatically. Any suggestions for such a device? I am planning on shooting some of my wild life shots with a tripod this spring.
Adam
Adam
    Nikon Forums Staff
  • Administrators
  • 1,335 posts
Gimbal heads are fairly common for telephoto use.  They're not cheap, though!
I have this model and it's worked fairly well for me out in the field.
http://www.bhphotovi...=5981
Daniel
Daniel
  • 512 posts
Thanks for the info Adam. I don't want to cut corners on price for a good tri-pod head so that price looks ok to me.
nbanjogal
nbanjogal
  • 2,094 posts
  • LocationUT, USA
I'm drooling…I need a new tripod head too--my current Manfrotto ball head can't hold up under the weight of my D600 and a 14-24mm. This gimbal head looks amazing.
Long Exposure
Long Exposure
  • 151 posts
  • Location26.82N, 80.06W
And this is what I use.  The "leg" slided into my ballhead and the foot attaches to the lens foot.  I like it because it is : a) more inexpensive than a full gimbal, B) it weighs less than a full gimbal (when throwing it in a pack, for example) and c) it is smaller and therefore easier to stow.
http://www.bhphotovi...ck_Ball_to.html
Alternately, I use the RRS 55 ballhead.  It has a ton of friction yet you can swing around the camera/lens combo.  I have "held up" meadium format gear with this beast.
It is big and expensive, you might want to sit down.
http://www.reallyrig...ory.567/it.C/.f
Edit:  Oh, and FWIW, I have had a D3 w/ a 2.8, 300m w/ a 1.4TC on the ballhead.  No issues.  None.
Daniel
Daniel
  • 512 posts
I'm using the Nikon 80-400mm and Sigma 150-500mm and the D800e is kind of heavy so I need something that could take the weight.
The trouble with a Wimberley for non-collared lenses is that the quick-release is oriented the wrong way, so you will need a $85 accessory to mount a body to the head. For a heavy wide-angle zoom a good ballhead like a RRS BH-55 or a Markins M-20 works better.
I agree with Long Exposure that a good, sturdy ballhead and a sidekick is the best way if you are not a birder and use the long lenses exclusively.
Long Exposure
Long Exposure
  • 151 posts
Merco, I agree.  Both of the ballheads you call out are great.
Daniel
Daniel
  • 512 posts
I got myself a MILANO M-GHPRO gimbal head. I will post some pics later with this setup. I already have a good carbon fibre tripod for it but think maybe I should get an even bigger one. I was looking around for a filter at the camera store when I noticed this tripod head was 50% off. So I bought it on the spot and saved 200$. It seemed like a good head when displayed at the store but I haven't actually trided it yet. So no reviews yet.
Full gimbal heads come into their own on Sachtler ENG-2 and Gitzo series 5 systematic tripods. You will need a base that is even sturdier than the head.
Daniel
Daniel
  • 512 posts
My tripod is already on the big side but I bought a smaller head last year when I purchased it. I'm thinking it might be on the smaller side for this head though. I never knew there was bigger heads like this last year when I bought it. Until I set out and at one place in Bella Coolla where people were waiting for grizzly's a guy had one and was panning around with it.
PrettyCranium
PrettyCranium
  • 410 posts
Does the Wimberley Sidekick work with Manfrotto ball heads?
Daniel
Daniel
  • 512 posts
I don't new? Maybe somebody does here.
I have never seen a Sidekick that was made for other than Arca-Swiss dovetails. You could probably adapt one, but it might be easier and even cheaper to get an Induro, Cullmann or other relatively cheap ballhead made for the Arca system.
Long Exposure
Long Exposure
  • 151 posts
Induro ballheads are crap.  The legs are fine, but I once traded out the ballhead from an Induro unit to a different maker as soon as I could.
I have only seen two Induro heads up-close but they seemed to work about as well as a Manfrotto 168. Perhaps the quality is inconsistent? I would definitely recommend a Cullman over the other cheap heads if one just cannot find the money for a good ballhead.
