Aperture blows out exposure with Nikon raw files
Started by pebbleheed, Feb 06 2014 05:23 PM
Posted 06 February 2014 - 05:23 PM
I'm having a problem with Apple's aperture software and my D5300.
When I import the raw files to aperture the previews look great. I appreciate these are camera generated however. When I open the raw file aperture immediately develops the file with a blown out exposure. It's ruining my photos.
I've tried changing settings. I've tried fixing images. Nothing is working.
Anyone experienced this and have any solutions?
Thanks
Thanks
Posted 08 February 2014 - 02:24 PM
Seems the fix is simple, but annoying.
To get around this I tried the aperture library loaded in iPhoto. The raw files load perfectly without any changes, exactly as they are on the camera.
Upside is I can use iPhoto to manage my workflow. Downside is that I miss all the advanced features of aperture that aren't present on the more simple iPhoto software.
Can't find a solution or setting change for aperture. Can't see why it would handle raw files differently to iPhoto as surely they'd use the same engine for raw work?
Shame, but aperture will have to sit on the unused pile for now.
Posted 08 February 2014 - 04:52 PM
I know nothing about Aperture, but perhaps there is a preset somewhere that needs altering or maybe even downloading for Nikon, or your camera. Or maybe make your own and save it. Just stabs in the dark.
Posted 08 February 2014 - 05:24 PM
I suspect it's either a setting that I can't find or it's something different between how the two apps handle raw files.
It didn't do this on my canon 650D. It seems the raw files from the nikon confuse it a little and it wants to make them a lot more exposed.
Posted 08 February 2014 - 09:41 PM
Have you tried resetting your import settings?
In the Import browser, choose Reset to Defaults from the Import Settings pop-up menu.
Posted 09 February 2014 - 04:11 PM
I did some research on the Apple forums.
It appears there's a known issue with the D5300 RAW / NEF files and how some Apple software handles them - as in it doesn't, or not very well anyway.
Some report issues with Preview and iPhoto whereas others report issues with Aperture. For me Preview and iPhoto is fine, but Aperture isn't.
I've raised it with Apple, I'll see if they respond with anything helpful.
In terms of the update file, it's all done and properly installed.
Posted 10 February 2014 - 04:27 AM
I've played about with aperture and found a temporary fix until Apple sort things out.
When the image loads I use the quick fix options to reduce the exposure by either -1 or -2 and then use colour punch. This gets the image back to almost how it was before.
Not the best situation but at least I can use aperture now.
Posted 28 February 2014 - 06:58 AM
Apple ignored my email, but I found a fix myself anyway.
Install iPhoto and aperture. Set iPhoto up as the default camera import software. Import all raw / nef files with iPhoto. Close iPhoto and load aperture, edit away!
Seems the issue is resolved if iPhoto imports the photo in to the library before aperture opens it rather than aperture importing it.
For this to work you must have iPhoto and aperture sharing the same library.
