D800E
focus shutter release
fireinvestigations
fireinvestigations
I have a D800E, this problem just started. I can take pictures indoors with or without a flash with no problem.
When I go out in daylight the camera focuses but the shutter will not release. I move focus point to get contrast and nothing. I have to focus then shift to manual and the shutter will release. I have reset the camera multiple times with no luck.
  • 10,630 posts
Have you tried shooting with continuous autofocus? This sets the shutter to release priority instead of focus priority. I like to use back button focus with AF-C and exposure lock on shutter half-press as a standard setting.
fireinvestigations
fireinvestigations
Thanks for the response, I think I have found the problem by accident, I changed cameras to see if it was a lense problem or camera problem. I was having difficulty connecting the Lense, I found the screws were loose on the F-mount. I tightened the screws and the problem went away.
Thanks for any responses.
Bob
Ellinor William
Ellinor William
  • 127 posts
I would suggest check the autofocus & Make sure you are not using a specific shooting mode or settings that may prevent the shutter from releasing.
For example, in some shooting modes like Self-Timer or Mirror Lock-Up, the camera may delay the shutter release or require additional steps before capturing an image. Also, verify that any exposure delay or bracketing settings are disabled.
Also tagged with one or more of these keywords: focus, shutter release
