Nikon d3200 live view error
Posted 21 March 2023 - 03:25 PM
"Cannot start live view curent setings or under curent conditions".
And "playback not curently avaliable"
I try change sd card, reset but same
Posted 26 March 2023 - 07:42 AM
Posted 26 March 2023 - 08:00 AM
It is one of your current settings that causes this behaviour.
Without knowing what settings you have chosen, it is not possible to help you.
Posted 26 March 2023 - 12:50 PM
("cannot start live view at curent setings or under curent conditions")
Batery not original, could that be the problem?
Posted 26 March 2023 - 01:09 PM
Posted 26 March 2023 - 01:49 PM
Posted 26 March 2023 - 01:54 PM
Posted 26 March 2023 - 02:06 PM
Posted 26 March 2023 - 03:12 PM
Posted 30 March 2023 - 03:14 AM
Nikon d3200 update - Nikon DX DSLRs - NikonForums.com
I guess that the liveview error mentioned in this thread was your initial problem which made you want to update the firmware
On top of the reset, you might want to check to
- remove the battery from the camera for at least 24h (ensure for it being fully charged before reinserting)
- try with another lens (to exclude that there is an electronic issue in or caused by the lens)
- eventually clean all accessible (visible) electric contacts with a de-oxidation product and check that the contacts fi in the SDcard slot are not bend.
- Gaston33 likes this
Posted 01 April 2023 - 01:29 PM
i try this but still have problemThe firmware update issue having been discussed in the thread
Posted 02 April 2023 - 12:27 AM
I’d suggest to bring it to a camera shop to see with one of the local tech guys says. Sending it in to a Nikon repair centre is likely more expensive than the camera’s value.
Posted 03 April 2023 - 11:36 AM
File upload & sharing. Send large photos and videos. Online cloud storage.If none helps then I am out of ideas what to try or check without having had the camerainn the hands.
Posted 19 April 2023 - 07:30 AM
I sent into to service center.If none helps then I am out of ideas what to try or check without having had the camerainn the hands.
processor board failure-this is problem
- Jerry_ likes this
