Hello, I'm hoping someone can help a rookie out! I have a Nikon D3200 flash with a Af-S DX NIKKOR 18-200MM F/3.5-5-56G ED VRII Lens. I recently purchased a Meike MK320 Speedlite to improve over the built-in camera flash but I can't get it to work! Every flash photo I take appears dark as if no flash was used at all. I can see the flash fire through the lens so I know it's working. I'm not trying to be fancy, I'm using the flashes TTL mode [i-TTL] with the 'Auto' setting on the camera so I thought it would just work, easy-peasy, but I'm very frustrated. Is there some setting I need to change to get it to work? I'd appreciate any help! I should also mention that the built-in flash works fine no matter what setting I'm using; Auto, Aperture Priority, Shutter Priority, etc.
Can't get i-TTL hot shoe flash to Sync?
Started by y2ken, Mar 13 2023 02:15 PM
flash d3200 af-s dx nikkor 18-200mm sync
Posted 13 March 2023 - 02:15 PM
Posted 14 March 2023 - 06:45 PM
I've never owned either the D3200 or the Meike flash, but I would suggest, as a test...
Set the camera on manual
Set your shutter speed to 1/60ths of a second
Set your lens to f/16
Set your flash to TTL
Photograph something in the five to eight foot range
See if you get an image. If that doesn't work, try setting your flash to Auto or Manual and repeat the test.
Also tagged with one or more of these keywords: flash, d3200, af-s dx nikkor 18-200mm, sync
Camera and Photo Help →
Beginner Questions →
Pairing Nikon D500 to Godox TT685IINStarted by timhendo, 09 Feb 2023 ![]() |
How to use the Live monitor with Flash (Z9)?Started by TWheelerWales, 13 Jan 2023 ![]() |
How to run a Nikon D3200 from a computer?Started by Chris H., 04 Aug 2022 ![]() |
Nikon Cameras →
Nikon DX DSLRs →
Nikon D3200, coping with an unusual error.Started by michalakopoulos, 16 Apr 2022 ![]() |
flash over exposure on close ups D5000Started by wmff, 22 Sep 2021 ![]() |
