I put on a neutral density filter. to shoot a shot with moving water. I always shoot in A priority with the ISO set at base 64. But the camera indicated "auto" ISO. When I changed the ISO back to 64 it also changed (opened up) the aperture. How can I set the aperture and ISO to where I want it and let the shutter speed fall where it may?
Using a ND filter and issue with aperture priority. D 850
Started by Brian B, Mar 08 2023 06:22 PM
Posted 08 March 2023 - 06:22 PM
Posted 10 March 2023 - 12:48 PM
To me the (A)perture priority mode sounds correct for what you try to do.
I tried to simulate what you describe on my D850 and it acts as expected. (FW: C1.10 / LD 2.017)
One thing to realize is that the shutter speed max length is 30’’ and that will not adapt beyond even if the picture is overly underexposed (as may be with the ND filter), until YOU open up the Aperture or change ISO
As with flowing water you might want some DOF, especially if you see the static elements (border, stones in the water), I would start with
1/ setting the camera to A (as you did)
2/ set an Aperture opening for the wished DoF
3/ start increasing the ISO setting until the moment I see the light meter showing a value (bars starting to appear to the left)
Alternately, if you want to absolutely have the ISO 64 setting along your chosen aperture, I guess that you have to go to (M)anual and set the exposure to BULB. Then it will be up to you to experiment for how long to expose your picture.
However having water flows smoothened with long exposure time would normally not require exposure times above 30’’. Therefore my option would be to go for the (A)-mode, allowing for a higher ISO.
