Cleaning the Lens
lessimon
lessimon
What is the best way to clean crud from an old 55mm lens, serial no. 972964? After cleaning the lens with air, microfiber cloths, lens tissue, and lens cleaning solution, a bit of crud remains. Your suggestions are appreciated. Many thanks.
  • 10,588 posts
Which 55 mm lens is it? From the serial number, I guess it is a late 1977 or maybe early 1978 Ai 55/3.5 Micronikkor.
Have you tried a Lenspen? Try to get the original (made by Parkside Optical) if you can find one.
I use ROR lens fluid on the glass w/ a microfiber cloth, and rubbing alcohol on the body.
https://www.amazon.c...e/dp/B0002HMRF2
