not sure that good idea or safe. do not want to lose cards if did that way. what your take on that.
some said to fix wise 512 issue was format on computer then Z9
Started by fallout666, Jan 17 2023 02:49 PM
Posted 17 January 2023 - 02:49 PM
Posted 17 January 2023 - 04:00 PM
Always follow your camera manufacture's approved procedures. In most cases, I think that means formatting your memory cards in camera. I've never heard of formatting a card in the computer and then formatting it again in camera.
If the card remains unreadable after being formatting in camera, I would suspect a bad card, and try another one. If that one also fails, I would then suspect the camera... provided the memory card brand you're using is on Nikon's list of approved cards.
- TBonz likes this
Posted 17 January 2023 - 04:08 PM
My take:
formatting a disk/card adapts it to the specifications of the system on which formatting is done, unless it does a « quick format ».
Therefore, in general, this is good and should not harm the card.
As users will want to read the « Nikon formatted » card in their computer (Windows, OSX, Linux) I suppose the format is ExFAT.
The only point to validate when formatting on the computer is therefore to use the good format. Worst case you choose the wrong format and need to reformat with a valid one.
Posted 18 January 2023 - 07:34 AM
for some reason the computer thinks card a Z6 and not Z9 and camera will not see cards unless i put into Z6 first. so off to buy new memory cards and use only one Z9 but first get new card reader to see if that will fix it.
