I have just ordered a Nikkor Z MC 105mm f/2.8 VR.S Lens and was wondering if anyone knows if I will be able to fit a Z 2xTC to it.
Cheers.
Cheers.
will not work. read this. it never work for my 1.7 one any of my smaller lenses when i had one
The rear element sits too far back to fit a TC. Don't even think about trying if it fits as it's an aspherical element and the repair will be very expensive if you scratch it.
I'll put in a link to the source Chris copied his information from.
https://imaging.niko..._tc_2x/spec.htm
Cheers guys. I did not order the lens thinking it would fit, it just occurred to me that it might,
Thanks anyway and I wish you all here on this site a happy and healthy 2023
It is a wonderful macro lens now, after the firmware update. The variable, accelerated focus throw it had originally made it difficult to focus manually. With the long, user-selectable linear throw it has now, it is one of the better macro lenses in production. It is, of course, not even close to classics like the Voigtländers and is a bit short for dragonflies or damselflies.
Thanks Peter,
It was the write-up and spec that sold it to me, and as it fell within my budget, I thought I would go-for-it.
It was this lens or the new Z 28-75mm f/2.8 which also seems to be a good investment according to its write-up. Its just that I had previously been considering the Z 24-70mm f/2.8 which is more than twice the price, and thought, 'how the hell have they managed to cheapen this similar lens by over 50%'. It has to be on the specification dos'nt it ???
No not actually as a clear cut decision as that, I was after a Macro lens.
When I decided to get a macro lens in Z-mount, the 105 was still unobtainium in Sweden. I bought the Laowa to get something when I needed it and not in a couple of months… I didn’t like the typical focus-by-wire accelerated throw the Nikon lens had. The Laowa has a too short throw, but it always moves the focus the same way, so building up a muscle memory as one uses it works. I will probably have a business use for the Nikon in the coming months, so it is time to get it. It is a wonderful lens with the updated firmware.
The 24-70 has state of the art glass and coatings, as it should bearing the S designation and selling in the premium cost bracket. The 28-75 OTOH, is made for the price-conscious prosumer who wants good optical performance at a reasonable price point. The 24-70 is good enough for architecture and has remarkably low vignetting, even without any lens profile applied. This matters much more to the working pro than the high purchase cost as the time spent in post is expensive. The 28-75 is an absolute bargain when one doesn’t have to think about billable time over the lifespan of the lens.
I think then that once the funds become available, I will have a closer look at the 28-75mm f/2.8.
I have the 70-200mm f/2.8 and was looking for the infill lens. The 24-70mm f/2.8 is listed at ÂŁ2100 here.
ÂŁ800 for the 28-75mm f/2.8 has to be considered.
Thanks guys.
Incidentally, for anyone that's wondering, the Z 70-200mm f/2.8 will fit the Z 2xTC
Also
The F 70-200 f/2.8 would not fit the F 2xTC but the F 70-200mm f/4 would.
Regarding the Z MC 105mm F/2.8 Lens that I purchased recently and previously mentioned, are there extension tubes / rings available in Z mount format ?
I am just looking at increasing the close-up ability of this lens. (Something else to play with lol)
I have done a search on a couple of local photographic sellers with no results.
The other thing, if these are available, would you use them with this lens, or steer clear ?
Also, are there other things to bear in mind when using extension rings ? I assume you have to focus manually when using these.
Thanks John
The problem with extension rings with a more or less IF construction is that you will get chromatic aberrations as the close-range correction group won't be in the correct location anymore. To get more magnification, I would rather get a Raynox DCR-250 than extension tubes with a modern lens.
There are tubes available, Thom Hogan has a list...
I had a look at the Raynox DCR-250 Peter and yes, it looks good.
If I bought one would you recommend me buying a 49mm filter for it.
If yes, what type of filter would you suggest ?
Also, in my searching, I saw a set of JJC Close Up Filters, +2, +4, +8, & +10, size 62mm for my Z MC 105mm Lens. I just wondered if you have tried using this sort of thing and, if yes, what you thought of them.
Cheers
John
Thanks Peter, I thought they would not be much good for me but thought I would ask.
I do value your knowledge.
What about a filter for the Raynox.
Would it be a worthwhile purchase ? and what type would you suggest for my MC lens
Thanks
Thanks for your thoughts. You did suggest using UV filters for protection sometime ago, and I have UV filters fitted to every one of my lens. Hoya on all my DX Lens, and URTH (Ex GOBE 2pk) on all my FX and Z Lens.
I only asked the previous question as, shooting close-up with artificial lighting and no lens hood, I thought I would need something to prevent stray light entering the lens, ie some sort of filter.
I found the DCR-250 on Amazon and a suggested addition for it was a K&F Concept Black 1/4 Mist Soft Glow Diffuser Lens (Nano K Series).
I was thinking that this may be the item to prevent the entry of stray light.
I've never heard of it before, but then I've not been around this stuff for very long.
Any thoughts on this please
Regards John
The Black Mist Soft Glow filter seems to be one of those effects filters that played an important, though niche, role in the analog process.
I think that a Lighroom or Photoshop action could be made to mimic the filter in post, just like a redhancer or any of the other FX filters that were indispensable when we all shot film 20 years ago.
The greatest advantage of applying the effect in post in PS is that you can adjust the amount of the effect by applying it to a layer and adjusting the opacity of the layer.
To prevent the loss of contrast due to stray light, a good lens hood works really well. A filter just introduces more glass-to-air surfaces, making flare even more pronounced if it occurs.
Oh yes I do agree, but I cant fit a lens hood with the DCR attached. I have ordered the DCR and the afore mentioned filter, and will see how it works out. It was'nt that expensive so thought I would try it anyway.
I will see what the results are, with it and without it, when using / not using lighting.
Thankyou.
