Hello, friends. I have a problem with a small brown spot appearing on every picture I take with my Nikon D7100. Yesterday I cleaned the wide angle lens I have on it, plus the UV filter mounted on the lens. I also brushed out the mirror inside the body. But the spot is still there. Any ideas on what else to do to remove it?
Posted 30 November 2022 - 11:09 AM
Posted 30 November 2022 - 12:15 PM
Sounds like sensor spots. You need to do a sensor clean cycle. I don’t have a D7100 manual downloaded on the iPad, so I can’t check the precise procedure for you. If you look for sensor cleaning, you will find the relevant passages.
You start by starting a mirror up cycle from somewhere in the settings menu. Don’t just do a normal mirror up as the shutter won’t open doing that.
When you have the mirror up and the shutter open, look all over the sensor area for dirty marks, dust, moisture drops or moisture rings. First try getting rid of the marks with a Giottos Rocketblower or equivalent. Don’t use a cheap blower, they tend to contaminate more than they clean…
If this doesn’t help, you need a wet clean. Either get it cleaned professionally or get a sensor cleaning kit made for DX sensors. Keep to one system, don’t get swabs from one brand and cleaning liquid from another as they are designed to be used as one system.
An uploaded photo showing the problem would be helpful as we can probably see from how the spot looks what has caused it.
Posted 01 December 2022 - 10:42 PM
Thanks very much, Nikonian. I have my manual, so I think I can follow the instructions to do what you suggest.
In the meantime, I'll try to upload a photo illustration.
Thanks again.
Posted 02 December 2022 - 07:41 AM
Posted 02 December 2022 - 10:19 AM
Posted 02 December 2022 - 02:28 PM
It works
For crop sensor cameras
https://www.amazon.c...n,aps,76&sr=8-4
For full frame cameras
https://www.amazon.c...t,aps,58&sr=8-3
Posted 02 December 2022 - 05:39 PM
Get a sensor cleaning kit from Amazon. I recently had a dirty sensor too.
… or support your lokal camera store rather than the evil empire! There are too few brick and mortar stores left today because of the convenience of mail order.
Posted 03 December 2022 - 11:50 AM
Here's a picture with the spot on the gray roof, to the left side of the entrance.
I found the sensor cleaning menu on my D7100 and tried it. It didn't remove the spot. I think my next step will be to take it to a camera shop where I've done business before.
Thanks for all the input.
Posted 03 December 2022 - 12:04 PM
Definitely looks like a dust spot. A professional cleaning gives you both a clean sensor and peace of mind. The first few times you clean the sensor, there is the doubt that one is doing it right…
- Ron and Bent_Rider like this
Posted 03 December 2022 - 02:31 PM
That's a giant of a spot.
I would have thought it visible on the sensor with the lens removed & the mirror 'up'.
Posted 15 December 2022 - 12:47 PM
...and the rest of the story...
I just picked up the camera from the local camera store. It's clean! No more spots! Definitely worth having a professional clean it.
So I'm back in business, friends.
