F4s electrics dead
f4
f2stop
f2stop
I try to exercise my beloved F4s two or three times a year. Six months ago, I put in fresh batteries, it powered up, but I noticed the battery check didn't work. Took out the batteries, cleaned all contacts with an eraser, reinstalled - and then the battery check worked, but the camera otherwise was dead.
Seems like every time I removed and reinstalled the batteries, the two conditions flip-flopped. Either the camera worked or the battery check worked, but never both.
Shot a couple of rolls of film last month.
This month, camera is completely dead - no check light and no life despite several contact cleanings and different sets of fresh batteries.
Any suggestions where I should start looking for a failed connection?
  • 10,649 posts
I would open both parts of the MB-21 up and look for corroded or matt solder joints as you have cleaned the contacts. If I found nothing, I would send it for service and a full CLA.
I have had my F4E-s CLA'd yearly until I more or less stopped shooting analog 35 mm in 2017. I shot with three bodies and rotated them through types of usage to keep wear similar on all three. I don't remember when I bought them, but the one I have kept is in the 224xxxx serial range and they were all bought at the same time, so probably around January, or at least the first quarter 1991.
f2stop
f2stop
Thanks! I had looked at the contacts, but took another very close look and found a tiny amount of green on one. Scraped it off -- and I'm back in business.
  • 10,649 posts
An F4s on dry cells has so many failure points. I use soldered packs of Eneloops in my F4E to eliminate most of them.
To avoid future corrosion, a little DeOx-it Gold applied to the contacts will do wonders.
Also tagged with one or more of these keywords: f4
