Nikon D800 no longer cooperates with my two Nikkor lenes
SAL
SAL
I'm stuck! I have a Nikon D800 which no longer cooperates with my two Nikkor lens (one is the 70-200mm-1:2.8GII ED, the other Nikkor 50mm, 1:1.4 G).
It will work once or twice right after I snap it on, then the viewfinder goes darker and when I press the shutter, nothing. It won't even release.
I then put on my Sigma fixed-focus lens, 85mm, 1.4 and it works like a charm.
Have you ever seen this? Is this a common glitch with this Nikon body? Both lenses have work brilliantly for years with this body. And suddenly, nothing.
I've tried everything, researched everywhere. I even set my camera body back to its factory defaults, to no avail. I tried my two Nikkor lenses on my other camera body, they work well.
Thanks so much!
  • 1,449 posts
This sounds like a communication problem between the body and the lens.
They can be caused by mechanical (f.i. the ring is loose and needs firmly fixing), but are mostly electric ( i.e. the electric contacts on the body or the lens are oxydised or dirty)
First clean the contacts softly, but with a body of the age of a D800 you may need products like the one in the link here : https://www.amazon.c...G/ref=emc_b_5_i
Also, if you do such “cleaning”, process all elements (body and lens(es))
  • SAL likes this
  • 9,450 posts
The first step would be to check that bayonet and contact blocks are firmly fixed to the body and lenses. The next is DeoxIT Gold, just as Jerry_ said. DeoxIT doesn’t only clean, it stops new oxide forming for a while.
If you need to tighten any screws, remember that they are JIS, not Phillips or Pozidriv.
  • SAL likes this
SAL
SAL
Thanks so much, I will definitely try these suggestions as they make total sense!
Thanks so much and for taking the time!
  • 895 posts
The cleaning suggestion is worth a try. My Sigma 12-24mm auto -focus failed and has now been sent to Sigma for repair by the supplier.
  • SAL likes this
