Nikon 200-500 vs 70-200 2.8 with 1.7 converter?
zoom lens for sport telephoto comparison
Iain
Iain
  • 5 posts
For some time I have had a 70-200 2.8 paired with a D500 which, for the majority of photos is fine; the majority of my photography is of kayaking events which provide fast moving subjects and variable distances.  However, reach is sometimes an issue and heavy cropping can be required.  To try get over this, I have a 1.7 converter to further boost my 70-200 to 510mm with the crop factor.  Not satisfied, I have recently tried the 200-500 5.6 but I have to say that I really am on the fence if the £1,000 spent on this lens is worth while.  Results have been ok but the sharpness does not seem to be the same as with the 70-200 and some more distant photos e.g. 80mtrs have been disappointing.  Perhaps, as an amateur, I am expecting too much and should not expect the quality I see in similar photos taken by others on full-frame cameras and prime lenses.
Grateful for any views about this dilemma.
  • 10,649 posts
Neither, if you want really crisp shots @ 340 mm. The AF-S 80-400 or either 100-400 from Sigma or Tamron are better choices on your D500.
Here is a sample @ 330 mm with the 80-400.
  • 1,098 posts
i have one for my gen 1 70-200mm but to slow on Z6 so going to give  to bother when i see him so get 2 new lenses and teleconverter
Iain
Iain
  • 5 posts
Peter, thanks for your input.  Have done some reading around the 80-400 and have bagged a used (mint) lens for £1,100 which I will collect later today and will be using to photograph a national kayak competition over the weekend.  I will let you know how I get on.
  • 10,649 posts
Good luck! I know you will like it as long as it is the AF-S version you have got. I know I could handhold mine for ridiculously long exposures. The Harvards in my example shoot were at 1/60 to get those full prop discs.
  • 2,267 posts
I don’t think the 200~500 ever received particularly high marks for sharpness. Most of the reviews I read when it was first released stated that the lens was mediocre at best. Certainly not as sharp as the the 70~200 f/2.8.
Peter, I was today’s years old when I discovered that the RAF version of the AT-6 Texan was called a Harvard.
—Ron
Also tagged with one or more of these keywords: zoom lens for sport, telephoto, comparison
