Telephoto Lens Suggestion
Tex
Tex
Good Morning Everyone,
Looking for a suggestion as I'm finding tons of information out there, most of it conflicting, so I figured this was my best bet to see if someone can help point me to what I'm looking for.
I'm in Law Enforcement and I'm looking for a good quality telephoto lens that can provide good zoom capabilities and light intake as some pictures will be taken in low light.
My current setup is a Nikon D3300 with a AF-S VR Nikkor 18-55mm 3.5-5.6 G-II and an AF-S VR Nikkor 55-300mm 4.5-5.6 G-ED.
I'm looking for a lens that can provide up to around the equivalent of a "10x" zoom.
Good aperture size as some shooting will be done in low light/night.
Cost is a factor as I work for a governmental agency and they don't like to spend money.
Any help will be much appreciated.
Adam
Adam
    Nikon Forums Staff
  • Administrators
  • 1,293 posts
In terms of value I'd say it's hard to beat the Tamron if you are looking for a F2.8 lens:
https://www.bhphotov...m_f_2_8_di.html
At 200mm this is over 10x your base focal length of 18mm, but it certainly won't give you more reach than the 55-300mm.
If you do need more reach there's the Sigma 150-600mm, which is also cheaper but also roughly the same aperture as your existing lens:
https://www.bhphotov..._6_3_dg_os.html
Another consideration which might make things more economical in the long run would be to upgrade the body to something with more sensitive AF / better high-ISO performance.  Then you'd be able to get away with using slower/smaller lenses :)
  • 251 posts
  • LocationMaidstone, Kent
Hello @tex
good suggestions there from Adam.
I've been using a D3300 for the last six years and have the AF-s 18-300mm f3.5-6.3 VR
Considering it's an entry level camera, this setup has worked well for me in many situations.
Much will depend how much you want to spend.
I recently bought a D800E, which means having to buy some full frame lenses.
If you don't already have a huge selection DX lenses, now might be a good time to look at a full frame or a mirrorless system?
  • Tex likes this
Brian
Brian
  • 475 posts
A 300mm lens will give you about 9 times magnification compared to a normal lens for your camera. You have that focal length covered, do you need more magnification?
A 300mm F2.8 would be ideal, but cost double what an F4 lens will cost.
A 300/4 AF-S used:
Nikon Nikkor AF-S 300mm F4 D ED SWM IF Lens 300/4 AFS #109 | eBay
I have bought from this shop several times.
A 400mm lens is the next step up, Tamron and Sigma would be ones to look at. An F5.6 lens is affordable, but you need to ask yourself about the Lighting. A 400mm F4 will be expensive.
