nikon fm shutter release questions
pless
pless
new to the nikon fm and new to film slr photography
i have a nikon fm and nikkor ai-s 28mmf2.8 lens mounted
the camera and lens function normally at apertures 2.8 and 4
at smaller apertures than 4, the camera will not fire by pressing the shutter release
it will however fire, by pressing the shutter release button first then pressing the depth of field preview lever
is this normal? it seems way out of whack?
thank you in advance for any help and understanding you may give me here
tonyzoc
tonyzoc
  • 17 posts
This sound like a problem with the lens. The camera gets the aperture info from the AI pin around the camera lens mount. If you take the lens off and slide the pin to the left all the way does the shutter fire? On the lens, if you set it to f/22 and move the actuation lever on the back of the lens is it difficult to move? I'm thinking the lens is sticking and preventing the camera arm from moving the lens lever. Do you have another lens to test?
Sent from my ONEPLUS A6013 using Tapatalk
After looking at my FM... I'm thinking the connection between the camera lever and the lens is not aligned correctly and maybe the lens lever is slipping to the side of the camera arm and sticking. Check if the camera actuation arm or the lens lever is bent. I've attached a couple of pictures of what they should look like. 2c76129803b301793bfcc626457520d4.jpg450523307f18e07e649aa0e8780df4df.jpg
pless
pless
thank you, that is very helpful
the lens is clean and free of mechanical defects to the best of my knowledge
but the photo that you attached would seem to indicate that the 'camera actuation arm' on my camera is bent
thank you for the attached phots in your post it makes things very clear
pless
pless
thank you again
i very carefully bent the arm back to the position shown in your photos and the camera now fires and works at all aperture settings per normal
tonyzoc
tonyzoc
  • 17 posts
thank you again
Great. I have a 6006 that had the arm bent like that. I think it happens if someone turns the lens counter clockwise when trying to dismount.
