My closeup photos are too over exposed when I use the built in flash on my D5000. I am shooting close ups of flowers, insects, and the like, quite often in dimly lit, wooded areas; I am using the "Apature-priority auto" mode. Even though I shoot RAW images, dialing down the brightness setting can't compensate for the over exposure. I never had this problem with my D60. I tried higher ISO setting but then everything gets very grainy. I also tried setting the flash compensation to its lowest level, -3, but that didn't seem to have any effect. The only way I found so far to "fix" the problem is to physically cover about 75-80% of the flash, this works but I notice an odd odor and am worried I am going to eventually damage the flash unit.
I can't shoot in manual mode because most of the time I only have a very narrow window in which to even try to get focus much less try to adjust all the settings manually. Trying to carry around an external flash is also not a
realistic choice.
flash over exposure on close ups D5000
Started by wmff, Sep 19 2021 11:03 AM
Posted 19 September 2021 - 11:03 AM
Posted 27 September 2021 - 07:18 AM
It would be helpful if you could post an example image or two along with your EXIF information for the image...that makes it quite a bit easier to assist you,
Posted 03 October 2021 - 01:53 PM
I am confused. My post seems to have been duplicated somehow. My original post with all original replies that are asking the same question you are now asking can be found here:
flash over exposure on close ups D5000 - Beginner Questions - NikonForums.com
Please refer to this URL for answers to your questions. Thanks for your input.
