F4 aperture ring on lenses such as AF Nikkor 24mm 1:2.8
MichaelMyers
MichaelMyers
  • 7 posts
  • LocationMiami and India
When the F4 has a AF Nikkor 24mm 2.8 attached, if the aperture lock ring is "locked", the viewing window inside the Viewfinder looks down at the lens and only displays "22", as the aperture ring is locked there.  Presumably, if the aperture ring is not locked, the aperture ring will rotate, and the viewfinder will show whatever aperture has been selected.
For use on new cameras, the aperture ring should be locked.
On the F4, the reason why those smaller aperture numbers are printed on the lens, is so they can be
seen from the viewfinder.
My question is, when used on cameras like the F4, should that ring be locked?
  • 8,368 posts
That depends on what mode you are using. When you use Program or Shutter priority, the ring needs to be set to the fully closed down aperture to let the camera control the setting. In Manual or Aperture priority, you need to use the ring to control the aperture as the F4 doesn’t have a control wheel.
