Why does my full frame crop so much of the frame?
composition d750
ThinxPix
ThinxPix
Hello Forum!
Please forgive me if this is a dumb question.
So, I've recently made the switch from a crop frame (D5500) to a full frame (D750) and I noticed that that great big, full frame that I can see in my viewfinder is never what comes out in the photo. And sorry for not knowing terminology, but I get that there's a square "frame guide" in the viewfinder, but I guess I expected that with a full frame you'd get at least SOME of what's outside that boundary in the pic, but that's not happening.  What's outside that frame guide seems like about 40% of what's in the viewfinder.  Is that just extra stuff to help with the overall composition?  I don't know. It just seems weird to me that I should lose SO MUCH of what i can see in the viewfinder.  i thought I'd be getting MORE frame with a "full frame" camera.
Thanks for any help you can provide.
Adam
Adam
    Nikon Forums Staff
  • Administrators
  • 1,330 posts
Are you using an APS-C ("DX") lens?  If so, the camera will by default crop the image so that it doesn't captures areas not covered by the lens.
Swapping to an FX lens would solve this issue.
  • 10,340 posts
What lens do you have? If it is a DX lens, the problem probably is the auto-crop feature as Adam wrote about above.
If you have an FX lens, you probably have one of the crop modes active. See pages 110 - 114 in the manual.
ThinxPix
ThinxPix
Well well. It appears I do have a "DX" lens. It's the AF-S Nikor 55-300mm. I use it for capturing birds, animals, and nature scenes. Is there an FX lens you would recommend that I could do the same with? Thanks!
  • 10,340 posts
There are quite a few choices for an FX tele zoom to replace your DX 55-300. If you seldom use narrower than 200 mm on the D5500, a 70-300 will give you the same field of view as you are used to. When shopping for a 70-300, be aware that there are two AF-P DX versions as well as the FX AF-P VR one. You can look for a used AF-S 70-300VR, but they are out of production. The third-party 70-300 class are all older lenses with large sample variation.
If you want to get more into birding, a Nikon 200-500 or a Tamron 150-600 G2 will be a better choice.
If you want something relatively portable with a similar FOV to the 55-300, the expensive Nikon AF-S 80-400 or the quite a bit cheaper Tamron 100-400 are both nice lenses.
Also tagged with one or more of these keywords: composition, d750
