is lack of sharpness expected on 1.4g lenses?
8 replies to this topic
audioscavenger
audioscavenger
  • 29 posts
I have treat myself with a full frame 55mm 1.4 for my d5300, giving me actually around 70mm.
At full aperture, focus subject are not sharp. Even at low apertures, it's much better but not sharp
Is it expected for this lens?
Or is it because the d5300 dx has trouble focusing with full frame objectives?
  • 10,635 posts
Is it front- or backfocusing or is nothing quite sharp?
If it just misses focus, you have to send it in to Nikon for calibration or exchange it for another sample as your D5300 doesn’t have the AF fine tune feature of the D7xxx upwards cameras.
Even though the 50/1.4 is no 58/1.4 or manual focus 50/1.2, it should be acceplably sharp wide open and just slightly sharper closed down a bit.
Shooting with a DX body, a 50 gives the field of view of a 75 on FX but not the depth of field. It won’t provide quite the separation between subject and background of the longer lens on a bigger sensor.
audioscavenger
audioscavenger
  • 29 posts
So again, it's me and my bad luck, and a useless body. Got it.
Thanks
audioscavenger
audioscavenger
  • 29 posts
and parkinson in the hands
i did more testing with a tripod and there's clear improvement
this lens has no VR indeed
are some lense not meant for live shooting?
i have same issue with 35mm 1.8g DX
  • 1,802 posts
Hello @audioscavenger
I also have trouble holding a camera still. Generally, I use a tripod.
Although VR is a very useful feature to have, it will only reduce camera shake to a degree.
Fast shutter speeds are your friend!
  • 10,635 posts
@ what shutter speeds are you trying to handhold?
  • 2,261 posts
55mm f/1.4? Is this a Nikon lens?
  • 10,635 posts
I expect that it is a typo.
  • 2,261 posts
Well, I suspect that some part of that is wrong. But the OP never mentioned the brand.
