Recently bought a used D750 to go with my D7000, and none of my Nikkor lenses work on this body. They all work fine on the D7000.
The lenses in question are AF-s 500mm F4 IF-ED , AF 50mm F1.4 D , AF 28-105mm F3.5-4.5 D.
The problem when mounting any of those lenses on the D750 is that when turning them on the body mount, just before they get to the lock position, the info appears on the top LCD but it's flashing. When finally locked in place, its the dreaded F-EE message. Pressing the lock switch in, and rotating that lens slightly back by a tiny amount, the info appears properly on the top LCD and is not flashing like before, but of course this is not acceptable.
I asked the private seller some questions, and it appears that it was one of the serial numbers that was part of the Nikon recall to have the shutter replaced.
He said there was still some warranty left on the work they did with the shutter replacement, so he asked the Nikon service centre that he had originally used for the shutter replacement, why 3 AF/ AF-s lenses would not work. Their response was that due to the new mechanism, the first time mounting a lens, it should be set at maximum aperture first, then set aperture to the red minimum, and lock the aperture ring.
Firstly, that doesnt fit with the fact that the contacts are not lining up, unless they removed the body mount as part of their work, and re-attached the mount slightly out of line, if that is indeed possible. I would have thought that there was no possible adjustment for the mount, as surely they screw in the holes in just one place.
Secondly, how can that advice be relevant to G lenses , which have no aperture ring ?
For whatever reason, it does seem to me that the contacts are out of line, but i'm no engineer or Nikon expert
