Lens for D3300
tac88
tac88
Hi. I have a D3300. I currently use the nikkor 55-200 and the 18-55. At one point I will expand to a longer lens but the problem I have now is I’m going between the two lenses a lot at one event. Is there a wide angle or all purpose lens I can use for everyday shots. Thank you for your help
Adam
Adam
    Nikon Forums Staff
  • Administrators
  • 1,335 posts
There are plenty of options.  If you just want an all-in-one lens, there's the 18-200mm:
https://www.bhphotov...R_18_200mm.html
For slightly better image quality at the expense of a bit of reach, there's also the 18-140mm:
https://www.bhphotov...r_18_140mm.html
Finally, then there are superzooms like the 18-300mm, but you'll really take a performance hit at the long end of those.  I'd only recommend a superzoom if you plan on never swapping lenses.
  • 10,643 posts
Other nice choices are the Nikon 16-80 or  Sigma 17-70. They are both long enough to get some overlap with the 55-200 without any loss of optical quality.
