EN-EL15b battery query
guitarman67
guitarman67
Hi all,
I recently purchased a Nikon D500 and 500mm PF lens.  My query relates to the EN-EL15b battery. I’ve charged the battery (I have 2 of them) about 5 times from new. It seems to me that the battery drains a lot quicker than when I shot with my previous Canon gear (7Dii/100-400ii)
For instance, today I began my bird shoot at 2.45pm with the battery showing 100%.  By 4.45 pm I had taken 287 shots and the battery showed 35%. During that time I did “chimp” somewhat. I had the lens on VR (normal and sport) and the camera on AFC. In addition I have aeroplane mode on and wifi/Bluetooth disabled.
I’d really appreciate some advice as to whether you think the battery may be faulty or is this photo count about normal. Are there any other settings that I could change to maximize the number of shots I can get from fully charged?
Looking forward to your advice,
Paul
  • 10,630 posts
Turn instant review off as the excellent screen on the D500 is a power hungry beast. Get into the habit of keeping your finger off the shutter button when not actively shooting as the VR activates on half-press. Do you use rear-button AF activation? If not, try it. You will have much more control over when you use the AF, saving battery.
guitarman67
guitarman67
Many thanks for your reply. All is good now as I made some changes to the settings (including your suggestions). Cheers.
Copyright 1959
Copyright 1959
  • 13 posts
  • LocationFlorida
I hope you carry a fresh spare? The 1st thing I get with a new camera body is two battery's.
krag96
krag96
  • 1,319 posts
I don't know about the D500, but I solved my battery drain on my D700's by adding converted battery grips that take EN-EL4 batteries for the D3.  They go for quite a while on those big batteries.   The down side is, it may as well be a D3 with the added weight and size.
I just checked, you can convert the MB-D17 with a BL-5 battery chamber cover to use EN-El 18 or 18A battery.  That should give you quite a bit of power, and for a long time, if you still need the extra life.
