USB C Charging D780
6 replies to this topic
JohnW
JohnW
  • 4 posts
Can i use any USB C charger for the D780 battery? For example, can i use the USB C charger from my Samsung Tablet S5e, are the electrical specs the same for all USB C? Don't want to use PC as it would be too slow.
  • 3,458 posts
I can't directly answer your question, however every Nikon DSLR I have seen has come with a charger for the battery.  That charger should be used if the D780 came with the battery and charger.  Otherwise, I would suggest consulting the manual to see how Nikon recommends charging the battery.
  • 2,604 posts
To charge any rechargeable battery in a decent time, one
needs some power and unless you use a powered con-
nection… no reasonable way.
Now, all universal buses are not hot — read powered —
and capable to charge the way you would need it and
without damaging the pack.
The idea to use the original like charger is the best.
  • 7,615 posts
The EH-7P is a 15W charging unit and the original Nikon USB-C charger for the Z series and the D780. If Nikon have followed the standards, any USB-C charger should work, but that is a big if...
JohnW
JohnW
  • 4 posts
Hi all and thanks for the feedback.
The whole idea of having a USB C input is to allow connection to a PC but also to allow in camera charging.
Nikon sells their own charger, the EH-7P as Merco pointed out, for $60 U.S. but why pay for something you already have from another device.
I just want to make sure the specs are the same.
FWIW, Rockwell had this in his review
I love that I can charge via USB-C; no more external charger needed even though one is included.
Mine draws 478mA at 5V through a 99¢ USB-C cord and generic 5V USB charger.
  • 7,615 posts
His generic charger seems to be a 2.5W unit and such a slow charge is unlikely to damage anything. There are chargers out there that can deliver 45W or more. Who knows if the camera has a current limiter built in? If your available charger gives 15W or less, you are probably safe, but if you heat damage your camera using a third-party charger the warranty will probably not cover the repair.
JohnW
JohnW
  • 4 posts
Thanks Merco. Ill stick to the external charger for now. Interesting you bring up the warranty as im not even sure i have one. I bought the camera from a local reseller brand new for $500 less than all the big box stores here. I guess ill find out with the serial number if it is under warranty. In passing this my 5th Nikon and ive never had any issues, in fact ive never encountered any issues with electronic devices except for PC graphic cards which seem to fail within 3 to 5 years regardless of the price
