Upgrade my lens or camera?
Posted 15 July 2020 - 12:40 AM
Adam
Posted 15 July 2020 - 09:50 AM
The honest answer is we can't answer that question because we have no idea why you are considering a change. Do you find something lacking in your current equipment? Why are you considering a change?
Posted 15 July 2020 - 01:08 PM
Do you have plans to go FX soon? The 24-70 pro lenses are all heavy beasts that don't handle well on a D5xxx series body as they get uncomfortably front-heavy. It will work and render beautiful photos but you will probably not bring it with you nearly as often as you do the D5600/18-140 combo.
What do you find lacking with your current gear? Remember that going with an FX normal zoom will cost you nearly all the wide angle coverage you currently have. You might be better off with a Sigma 18-35/1.8 if you need a bigger aperture than the kit lens has for either shallower DOF or lower ISO, for example.
Posted 17 July 2020 - 02:45 PM
like both said. you should find true local camera store and try it out. as for merco_61 i had gen 1 nikon 70-200mm and gen 1 tamron 150-600mm no issue in till driop camera with gen 1 tamron 150-600mm he can use it. also do not know how many full frame lenses he has or what type of photography and budget to go on. that is great upgrade i would do it. but with so little info. only thing we can say.
